Ana içeriğe geç
Acer Iconia B1-720 Rear Case Replacement
Neye ihtiyacın var
  1. Acer Iconia B1-720 Rear Case Replacement, Rear Case: adım 1, 3 resimden 1. Acer Iconia B1-720 Rear Case Replacement, Rear Case: adım 1, 3 resimden 2. Acer Iconia B1-720 Rear Case Replacement, Rear Case: adım 1, 3 resimden 3.
    • Insert a plastic opening tool into a gap near the charging port at the top of the device. Slide the tool in either direction along the device.
  2. Acer Iconia B1-720 Rear Case Replacement: adım 2, 3 resimden 1. Acer Iconia B1-720 Rear Case Replacement: adım 2, 3 resimden 2. Acer Iconia B1-720 Rear Case Replacement: adım 2, 3 resimden 3.
    • Slide the tool along until you have completely separated the rear cover.
    • If needed, place the first tool in the gap created to hold this gap open and use a second tool to pry the remaining portion of the rear cover off.
  3. Acer Iconia B1-720 Rear Case Replacement: adım 3, 2 resimden 1. Acer Iconia B1-720 Rear Case Replacement: adım 3, 2 resimden 2.
    • Once all the sides have been separated, you should be able to simply lift the cover off of the device.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Phillip Keavey
319 İtibar
2 adet Kılavuz yazıldı
Ekip
Michigan Tech, Team 1-1, Lauer Spring 2015 Michigan Tech, Team 1-1, Lauer Spring 2015 üyesi
MTU-LAUER-S15S1G1
2 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 5
Her zaman: 839
