Ana içeriğe geç
Acer Iconia B1-A71 Touch Screen Glass Replacement
Neye ihtiyacın var
Videoya Genel Bakış
  1. Acer Iconia B1-A71 Touch Screen Glass Replacement, Acer Iconia B1-A71   Touch Screen Glass Replacement: adım 1, 3 resimden 1. Acer Iconia B1-A71 Touch Screen Glass Replacement, Acer Iconia B1-A71   Touch Screen Glass Replacement: adım 1, 3 resimden 2. Acer Iconia B1-A71 Touch Screen Glass Replacement, Acer Iconia B1-A71   Touch Screen Glass Replacement: adım 1, 3 resimden 3.
    • Because I can't switch-off the tablet, I'm using the reset button to do this.
    • With a cutter and a plastic tool remove the back cover.
    • If you have a memory card inside, don't forget to remove it!
  2. Acer Iconia B1-A71 Touch Screen Glass Replacement: adım 2, 2 resimden 1. Acer Iconia B1-A71 Touch Screen Glass Replacement: adım 2, 2 resimden 2.
    • First, disconnect the battery.
    • Now, disconnect the loudspeaker and remove the back cover.
    • Remove all scotch tapes and disconnect the touch screen flex cable...
    • LCD display flex cable,
    • the microphone,
    • and the WiFi and Bluetooth antennas flex cables.
  3. Acer Iconia B1-A71 Touch Screen Glass Replacement: adım 3, 3 resimden 1. Acer Iconia B1-A71 Touch Screen Glass Replacement: adım 3, 3 resimden 2. Acer Iconia B1-A71 Touch Screen Glass Replacement: adım 3, 3 resimden 3.
    • Unscrew 5x screws and rmove the main board.
  4. Acer Iconia B1-A71 Touch Screen Glass Replacement: adım 4, 3 resimden 1. Acer Iconia B1-A71 Touch Screen Glass Replacement: adım 4, 3 resimden 2. Acer Iconia B1-A71 Touch Screen Glass Replacement: adım 4, 3 resimden 3.
    • The battery is glued to the LCD display metal shield with a double sided adhesive tape.
    • Use plastic tools and carefully remove it.
    • Remove all tapes from the LCD display metal shield.
  5. Acer Iconia B1-A71 Touch Screen Glass Replacement: adım 5, 3 resimden 1. Acer Iconia B1-A71 Touch Screen Glass Replacement: adım 5, 3 resimden 2. Acer Iconia B1-A71 Touch Screen Glass Replacement: adım 5, 3 resimden 3.
    • The LCD display is held by metal frame and some locking clips on it.
    • Use a cutter and a plastic tool to separate the LCD.
    • You have to work slowly so as not to break the display.
    • Now, install the new LCD display and reassemble the tablet.
  6. Acer Iconia B1-A71 Touch Screen Glass Replacement: adım 6, 3 resimden 1. Acer Iconia B1-A71 Touch Screen Glass Replacement: adım 6, 3 resimden 2. Acer Iconia B1-A71 Touch Screen Glass Replacement: adım 6, 3 resimden 3.
    • Warm up the touch screen.
    • Start separating from one of the corners. With a cutter, make place for a plastic tool.
    • Keep warm the touchscreen to separate it easily.
    • For us is important to keep only the frame.
  7. Acer Iconia B1-A71 Touch Screen Glass Replacement: adım 7, 3 resimden 1. Acer Iconia B1-A71 Touch Screen Glass Replacement: adım 7, 3 resimden 2. Acer Iconia B1-A71 Touch Screen Glass Replacement: adım 7, 3 resimden 3.
    • Use again hot air and a plastic tools to separate the metal screen frame / holder.
  8. Acer Iconia B1-A71 Touch Screen Glass Replacement: adım 8, 3 resimden 1. Acer Iconia B1-A71 Touch Screen Glass Replacement: adım 8, 3 resimden 2. Acer Iconia B1-A71 Touch Screen Glass Replacement: adım 8, 3 resimden 3.
    • Before installing the new touch screen, clean the frame and put double side adhesive tape.
    • For the cleaning you can use an alcohol.
  9. Acer Iconia B1-A71 Touch Screen Glass Replacement: adım 9, 3 resimden 1. Acer Iconia B1-A71 Touch Screen Glass Replacement: adım 9, 3 resimden 2. Acer Iconia B1-A71 Touch Screen Glass Replacement: adım 9, 3 resimden 3.
    • Again use a double side adhesive tape to install the the metal LCD frame.
  10. Acer Iconia B1-A71 Touch Screen Glass Replacement: adım 10, 3 resimden 1. Acer Iconia B1-A71 Touch Screen Glass Replacement: adım 10, 3 resimden 2. Acer Iconia B1-A71 Touch Screen Glass Replacement: adım 10, 3 resimden 3.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
ZFix
191.308 İtibar
330 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
322 Üyeler
2.534 adet Kılavuz yazıldı
Bir Yorum
Hello, i have followed all these instructions but the touch screen desn't work in spite of a reset by the little button and a wipe.
Please, how can i resolve this problem?
houssnijanah - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 25,098
