Ana içeriğe geç
Acer Iconia One 10 B3-A30 Repair Camera Replacement
Neye ihtiyacın var
  1. Acer Iconia One 10 B3-A30 Repair Camera Replacement, Camera: adım 1, 2 resimden 1. Acer Iconia One 10 B3-A30 Repair Camera Replacement, Camera: adım 1, 2 resimden 2.
    • Make sure the device is powered off.
    • Pry open media port cover at the top of the tablet.
    • Use the Phillips 00 screwdriver to remove the 1 mm screw.
  2. Acer Iconia One 10 B3-A30 Repair Camera Replacement: adım 2, 3 resimden 1. Acer Iconia One 10 B3-A30 Repair Camera Replacement: adım 2, 3 resimden 2. Acer Iconia One 10 B3-A30 Repair Camera Replacement: adım 2, 3 resimden 3.
    • Using the metal spudger, carefully pry open the back cover.
  3. Acer Iconia One 10 B3-A30 Repair Camera Replacement: adım 3, 3 resimden 1. Acer Iconia One 10 B3-A30 Repair Camera Replacement: adım 3, 3 resimden 2. Acer Iconia One 10 B3-A30 Repair Camera Replacement: adım 3, 3 resimden 3.
    • Using the plastic opening tool gently place the tip of it under the connection and pry up. It will pop out.
  4. Acer Iconia One 10 B3-A30 Repair Camera Replacement: adım 4, 2 resimden 1. Acer Iconia One 10 B3-A30 Repair Camera Replacement: adım 4, 2 resimden 2.
    • Use the plastic opening tool to pry up the rear facing camera. Once removed the front facing camera will come out as well.
Sonuç
Austin Pickart
688 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G5, Nance Fall 2017 USF Tampa, Team S1-G5, Nance Fall 2017 üyesi
USFT-NANCE-F17S1G5
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 659
