Ana içeriğe geç
Acer Iconia One 10 B3-A30 Repair Power Switch Replacement
Neye ihtiyacın var
  1. Acer Iconia One 10 B3-A30 Repair Power Switch Replacement, Battery: adım 1, 2 resimden 1. Acer Iconia One 10 B3-A30 Repair Power Switch Replacement, Battery: adım 1, 2 resimden 2.
    • Make sure the device is powered off.
    • Open media port cover at the top of the tablet.
    • Use the Phillips #00 screwdriver to remove the 1 mm screw.
  2. Acer Iconia One 10 B3-A30 Repair Power Switch Replacement: adım 2, 3 resimden 1. Acer Iconia One 10 B3-A30 Repair Power Switch Replacement: adım 2, 3 resimden 2. Acer Iconia One 10 B3-A30 Repair Power Switch Replacement: adım 2, 3 resimden 3.
    • Using the metal spudger, carefully pry open the back cover.
  3. Acer Iconia One 10 B3-A30 Repair Power Switch Replacement: adım 3, 1 resimden 1.
    • Remove small section of grey tape.
  4. Acer Iconia One 10 B3-A30 Repair Power Switch Replacement: adım 4, 2 resimden 1. Acer Iconia One 10 B3-A30 Repair Power Switch Replacement: adım 4, 2 resimden 2.
    • Unplug the connection cord from the motherboard.
  5. Acer Iconia One 10 B3-A30 Repair Power Switch Replacement: adım 5, 3 resimden 1. Acer Iconia One 10 B3-A30 Repair Power Switch Replacement: adım 5, 3 resimden 2. Acer Iconia One 10 B3-A30 Repair Power Switch Replacement: adım 5, 3 resimden 3.
    • Try to remove the battery by pulling on the blue tabs.
    • If unsuccessful, use the black plastic spudger to gently break the glue bonds underneath and pull up to remove the battery.
    • Be very cautious not to puncture or bend the battery.
  6. Acer Iconia One 10 B3-A30 Repair Power Switch Replacement, Motherboard: adım 6, 3 resimden 1. Acer Iconia One 10 B3-A30 Repair Power Switch Replacement, Motherboard: adım 6, 3 resimden 2. Acer Iconia One 10 B3-A30 Repair Power Switch Replacement, Motherboard: adım 6, 3 resimden 3.
    • Remove all of the tape surrounding the motherboard.
  7. Acer Iconia One 10 B3-A30 Repair Power Switch Replacement: adım 7, 2 resimden 1. Acer Iconia One 10 B3-A30 Repair Power Switch Replacement: adım 7, 2 resimden 2.
    • Starting with the 2 large connections use the plastic opening tool to gently pry on the connections and pop them out.
    • Now, disconnect the two smaller black and red cords from the motherboard.
  8. Acer Iconia One 10 B3-A30 Repair Power Switch Replacement: adım 8, 1 resimden 1.
    • Scrape away the small square sticker to reveal one small screw. Use the Phillips #00 screwdriver to remove the screw.
    • Using the same screwdriver remove the other three screws on the motherboard.
  9. Acer Iconia One 10 B3-A30 Repair Power Switch Replacement: adım 9, 2 resimden 1. Acer Iconia One 10 B3-A30 Repair Power Switch Replacement: adım 9, 2 resimden 2.
    • Using the small plastic tool, carefully pry the motherboard out of the device.
  10. Acer Iconia One 10 B3-A30 Repair Power Switch Replacement, Power Switch: adım 10, 2 resimden 1. Acer Iconia One 10 B3-A30 Repair Power Switch Replacement, Power Switch: adım 10, 2 resimden 2.
    • Depress power switch using finger, and simultaneously pry in same direction with a plastic opening tool.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Austin Pickart
688 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G5, Nance Fall 2017 USF Tampa, Team S1-G5, Nance Fall 2017 üyesi
USFT-NANCE-F17S1G5
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 4
Son 30 gün: 12
Her zaman: 1,976
