Ana içeriğe geç
Giriş
After removing the battery, motherboard, and speakers, you can access the screen. Through the use of a Phillips #00 bit and a black plastic spudger, we will show you how to remove the screen.
  1. Make sure the device is powered off. Open media port cover at the top of the tablet.
    • Make sure the device is powered off.
    • Open media port cover at the top of the tablet.
    • Use the Phillips #00 screwdriver to remove the 1 mm screw.
  2. Using the metal spudger, carefully pry open the back cover. Using the metal spudger, carefully pry open the back cover. Using the metal spudger, carefully pry open the back cover.
    • Using the metal spudger, carefully pry open the back cover.
  3. Remove small section of grey tape.
    • Remove small section of grey tape.
  4. Unplug the connection cord from the motherboard. Unplug the connection cord from the motherboard.
    • Unplug the connection cord from the motherboard.
  5. Try to remove the battery by pulling on the blue tabs. If unsuccessful, use the black plastic spudger to gently break the glue bonds underneath and pull up to remove the battery. Be very cautious not to puncture or bend the battery.
    • Try to remove the battery by pulling on the blue tabs.
    • If unsuccessful, use the black plastic spudger to gently break the glue bonds underneath and pull up to remove the battery.
    • Be very cautious not to puncture or bend the battery.
  6. Remove all of the tape surrounding the motherboard. Remove all of the tape surrounding the motherboard. Remove all of the tape surrounding the motherboard.
    • Remove all of the tape surrounding the motherboard.
  7. Starting with the 2 large connections use the plastic opening tool to gently pry on the connections and pop them out. Now, disconnect the two smaller black and red cords from the motherboard.
    • Starting with the 2 large connections use the plastic opening tool to gently pry on the connections and pop them out.
    • Now, disconnect the two smaller black and red cords from the motherboard.
  8. Scrape away the small square sticker to reveal one small screw. Use the Phillips #00 screwdriver to remove the screw.
    • Scrape away the small square sticker to reveal one small screw. Use the Phillips #00 screwdriver to remove the screw.
    • Using the same screwdriver remove the other three screws on the motherboard.
  9. Using the small plastic tool, carefully pry the motherboard out of the device. Using the small plastic tool, carefully pry the motherboard out of the device.
    • Using the small plastic tool, carefully pry the motherboard out of the device.
  10. Using a plastic spudger pry the square connection away from the screen. Using a plastic spudger pry the square connection away from the screen. Using a plastic spudger pry the square connection away from the screen.
    • Using a plastic spudger pry the square connection away from the screen.
  11. Using the Philips #00 head unscrew the screw holding in the small plate.
    • Using the Philips #00 head unscrew the screw holding in the small plate.
  12. Using the Philips #00 unscrew the remaining 4 screws along the two speakers. Using the Philips #00 unscrew the remaining 4 screws along the two speakers. Using the Philips #00 unscrew the remaining 4 screws along the two speakers.
    • Using the Philips #00 unscrew the remaining 4 screws along the two speakers.
  13. Using the plastic spudger gently pry the screen along the plastic clips. Once at least 1/2 of the screen is unclipped slide it out of the frame using hands.
    • Using the plastic spudger gently pry the screen along the plastic clips.
    • Once at least 1/2 of the screen is unclipped slide it out of the frame using hands.
Sonuç
14 farklı kişi bu kılavuzu tamamladı.
Austin Pickart
670 İtibar
5 adet Kılavuz yazıldı
Takım
USF Tampa, Team S1-G5, Nance Fall 2017 USF Tampa, Team S1-G5, Nance Fall 2017 üyesi
USFT-NANCE-F17S1G5
4 Üyeler
11 Yorum
nice job people!
Johnathon Ferland - Yanıt
It worked! I’m very happy
marmaesker - Yanıt
nice job
Linh Pham
Linh Pham - Yanıt
This helped out a lot, thanks
feje75 - Yanıt
Fantastic set of instructions. Very much appreciated. Cheers very much!!
Chris Wilson - Yanıt
To replace just the digitiser glass, could I just disconnect the black digitiser ribbon shown in step 7 and then use a heat gun on the front and remove the glass that way? Then I would just need to slide the new ribbon cable through and seal, with no need to remove the motherboard, battery etc.
In theory i’m sure this would work, I might try it and give an update in a week or so once my part arrives.
Liam Flatley - Yanıt
So for glass only does the battery and motherboard need to come out?
northstar -
thanks so much im soglad I don't have to use a mouse to type on my tablet anymore!!! what is thebest way to glue the battery though?
CozmicPlayz Minecraft - Yanıt
Is the LCD fused to the touch digitizer here? Wondering if I can just get the LCD, or need the complete assembly, because my touch layer still works, just the LCD is cracked
tipoo - Yanıt
tout s’est bien passé remplacement effectué, mais il n’est absolument pas nécessaire de retirer la batterie, en fait en déconnectant la tresse façade et en enlevant toutes les vis, on peut tout sortir d’un coup, rien d’autre à débrancher.
La seule vis à ne pas oublier d’enlever c’est celle qui est sous le petit carré de papier collant à proximité de la prise USB
Si non beau travail mais à simplifier
Daniel Popy - Yanıt
That wasn’t too bad, all fixed!
Just try to get the pull tabs out straight and clean, otherwise having to manipulate the battery (which seems to bend easy!) can be worrying.
tipoo - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 13
Son 30 gün: 54
Her zaman: 11,918
