Ana içeriğe geç
Acer Iconia One 7 Battery Replacement
Neye ihtiyacın var
    1. Acer Iconia One 7 Battery Replacement, Battery: adım 1, 1 resimden 1.
      • Begin prying the front from the back on any side of the tablet. Gently work your way around the tablet with the prying tool.
      FixBot'a Sor
      Yorum Ekle
    2. Acer Iconia One 7 Battery Replacement: adım 2, 1 resimden 1.
      • Using a plastic opening tool, separate the back cover from the main device.
      • Open each side continuously to ensure all sides have been separated.
      FixBot'a Sor
      Yorum Ekle
    3. Acer Iconia One 7 Battery Replacement: adım 3, 1 resimden 1.
      • Turn the tablet over so the battery is facing up.
      FixBot'a Sor
      Yorum Ekle
    4. Acer Iconia One 7 Battery Replacement: adım 4, 2 resimden 1. Acer Iconia One 7 Battery Replacement: adım 4, 2 resimden 2.
      • Carefully pull back the black tape covering the battery lead connector.
      • Disconnect connection with the board by pulling up on the wire with the plastic opening tool.
      FixBot'a Sor
      Yorum Ekle
    5. Acer Iconia One 7 Battery Replacement: adım 5, 3 resimden 1. Acer Iconia One 7 Battery Replacement: adım 5, 3 resimden 2. Acer Iconia One 7 Battery Replacement: adım 5, 3 resimden 3.
      Bu adımda kullanılan alet:
      Plastic Cards
      $2.99
      • Using a plastic card or opening pick, separate the battery from the rest of the device.
      • Do not use a metal spudger like seen in the example photos. Use a plastic card to avoid bending or rupturing the battery.
      FixBot'a Sor
      Yorum Ekle
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Ahmad Kayali
458 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 8-5, Eyestone Fall 2015 USF Tampa, Team 8-5, Eyestone Fall 2015 üyesi
USFT-EYESTONE-F15S8G5
3 Üyeler
25 adet Kılavuz yazıldı
4Kılavuz Yorumları
is there a replacement batt that can fit here or other brand that can fit? like from samsing tab? acer battery sucks
Stanley So - Yanıt Paylaş
Thank you for this guide, replaced my battery (very easy with guide) and now my tablet works good. Also saved me some money. Thanks
vlamar14 - Yanıt Paylaş
My acer iconia one 7 battery model is 308292 wnd there is no tutorial regarding replacing battery. Thank
wantalktasol - Yanıt Paylaş
Where I can order the new battery part?
melanieloa3 - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 57
Her zaman: 19,157
