Ana içeriğe geç
Acer Iconia One 7 Motherboard Replacement
Neye ihtiyacın var
    • Reminder: Turn off device before you start opening your tablet.
  1. Acer Iconia One 7 Motherboard Replacement: adım 2, 1 resimden 1.
    • Begin at any side of the tablet.
    • With a plastic opening tool, begin taking apart the back cover from the tablet by working along the edges.
    • Use caution when prying the lid open to avoid damaging your tablet.
  2. Acer Iconia One 7 Motherboard Replacement: adım 3, 1 resimden 1.
    • Using a plastic opening tool, separate the back cover from the main device
    • Open each side continuously to ensure all sides have been separated,
  3. Acer Iconia One 7 Motherboard Replacement: adım 4, 1 resimden 1.
    • Turn tablet over.
    • Lay the tablet on a flat surface with the screen facing down. Locate the copper cover along the outside of the tablet.
  4. Acer Iconia One 7 Motherboard Replacement: adım 5, 1 resimden 1.
    • Carefully peel back the copper foil to reveal the motherboard.
  5. Acer Iconia One 7 Motherboard Replacement: adım 6, 1 resimden 1.
    • Peel tape back to expose connections.
  6. Acer Iconia One 7 Motherboard Replacement: adım 7, 2 resimden 1. Acer Iconia One 7 Motherboard Replacement: adım 7, 2 resimden 2.
    • There are several sets of wires connected to the motherboard as shown in the images. Carefully disconnect each set of wires.
  7. Acer Iconia One 7 Motherboard Replacement: adım 8, 2 resimden 1. Acer Iconia One 7 Motherboard Replacement: adım 8, 2 resimden 2.
    • Use a JIS screw bit #00 to remove screws around the motherboard using the provided image to locate each screw.
  8. Acer Iconia One 7 Motherboard Replacement: adım 9, 1 resimden 1.
    • Gently pull out motherboard.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Michael
519 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 8-5, Eyestone Fall 2015 USF Tampa, Team 8-5, Eyestone Fall 2015 üyesi
USFT-EYESTONE-F15S8G5
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 4
Her zaman: 2,535
