Ana içeriğe geç
Acer Iconia One 7 Rear-Facing Camera Replacement
Neye ihtiyacın var
  1. Acer Iconia One 7 Rear-Facing Camera Replacement, Rear-Facing Camera: adım 1, 1 resimden 1.
    • Begin at any side of the tablet.
    • With a plastic opening tool, begin taking apart the back cover from the tablet by working along the edges.
    • Prying the lid open can be difficult, use caution in order to safely remove.
    • Turn off device before this step.
  2. Acer Iconia One 7 Rear-Facing Camera Replacement: adım 2, 1 resimden 1.
    • Using a plastic opening tool, separate the back cover from the main device.
    • Open each side continuously to ensure all sides have been separated.
  3. Acer Iconia One 7 Rear-Facing Camera Replacement: adım 3, 1 resimden 1.
    • Turn the tablet over to locate the camera on the top left.
    • Besides the parts that are mentioned in the instruction, try not to agitate other fragile components inside the device.
  4. Acer Iconia One 7 Rear-Facing Camera Replacement: adım 4, 2 resimden 1. Acer Iconia One 7 Rear-Facing Camera Replacement: adım 4, 2 resimden 2.
    • Peel black tape.
    • Detach clip from motherboard.
  5. Acer Iconia One 7 Rear-Facing Camera Replacement: adım 5, 2 resimden 1. Acer Iconia One 7 Rear-Facing Camera Replacement: adım 5, 2 resimden 2.
    • Take out film object using tweezers.
    • Using tweezers take out camera.
Sonuç
Michael
519 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 8-5, Eyestone Fall 2015 USF Tampa, Team 8-5, Eyestone Fall 2015 üyesi
USFT-EYESTONE-F15S8G5
3 Üyeler
5 adet Kılavuz yazıldı
Bir Yorum
How to get new camera if the original camera is damaged
Prakash Hasabnis - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 415
