Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
Giriş
The rear facing camera is utilized when taking pictures in front of the device. In this case it is separated from the front facing camera and works separately as well. Pieces regarding this camera are significantly small so be aware of any missing items.
Parçalar
Hiçbir parça belirtilmedi.
  1. Begin at any side of the tablet.
    • Begin at any side of the tablet.
    • With a plastic opening tool, begin taking apart the back cover from the tablet by working along the edges.
    • Prying the lid open can be difficult, use caution in order to safely remove.
    • Turn off device before this step.
  2. Using a plastic opening tool, separate the back cover from the main device.
    • Using a plastic opening tool, separate the back cover from the main device.
    • Open each side continuously to ensure all sides have been separated.
  3. Manta Tornavida Seti
    112 bits for every fix.
    Upgrade Your Toolbox
  4. Turn the tablet over to locate the camera on the top left.
    • Turn the tablet over to locate the camera on the top left.
    • Besides the parts that are mentioned in the instruction, try not to agitate other fragile components inside the device.
  5. Peel black tape. Detach clip from motherboard.
    • Peel black tape.
    • Detach clip from motherboard.
  6. Take out film object using tweezers. Using tweezers take out camera.
    • Take out film object using tweezers.
    • Using tweezers take out camera.
Sonuç
Michael
513 İtibar
4 adet Kılavuz yazıldı
Takım
USF Tampa, Team 8-5, Eyestone Fall 2015 USF Tampa, Team 8-5, Eyestone Fall 2015 üyesi
USFT-EYESTONE-F15S8G5
3 Üyeler
5 adet Kılavuz yazıldı
Bir Yorum
How to get new camera if the original camera is damaged
Prakash Hasabnis - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 328
