Ana içeriğe geç
Acer Iconia One 7 Speaker Replacement
Neye ihtiyacın var
  1. Acer Iconia One 7 Speaker Replacement, Speaker: adım 1, 1 resimden 1.
    • Begin at any side of the tablet.
    • With a plastic opening tool, begin taking apart the back cover from the tablet by working along the edges.
    • Prying the lid open can be difficult; use caution in order to safely remove.
    • Turn off device before this step.
  2. Acer Iconia One 7 Speaker Replacement: adım 2, 1 resimden 1.
    • Using a plastic opening tool, separate the back cover from the main device.
    • Open each side continuously to ensure all sides have been separated.
  3. Acer Iconia One 7 Speaker Replacement: adım 3, 1 resimden 1.
    • Turn the tablet over to locate the speaker.
    • Besides the parts that are mentioned in the instruction, try not to agitate other fragile components inside the device.
    • The speaker is on the bottom of the inside.
  4. Acer Iconia One 7 Speaker Replacement: adım 4, 2 resimden 1. Acer Iconia One 7 Speaker Replacement: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Peel back tape.
    • Using tweezers, detach connection from motherboard.
  5. Acer Iconia One 7 Speaker Replacement: adım 5, 3 resimden 1. Acer Iconia One 7 Speaker Replacement: adım 5, 3 resimden 2. Acer Iconia One 7 Speaker Replacement: adım 5, 3 resimden 3.
    • Unscrew screws with a JIS screwdriver with a #00 screw bit.
    • Dislodge the speaker unit.
    • Take care not to displace any other bits in the device.
Sonuç
Michael
519 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 8-5, Eyestone Fall 2015 USF Tampa, Team 8-5, Eyestone Fall 2015 üyesi
USFT-EYESTONE-F15S8G5
3 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 21
Her zaman: 449
