Ana içeriğe geç
Acer Iconia One 8 Battery Replacement
Neye ihtiyacın var
  1. Acer Iconia One 8 Battery Replacement, Battery: adım 1, 2 resimden 1. Acer Iconia One 8 Battery Replacement, Battery: adım 1, 2 resimden 2.
    • To remove the back panel, insert an opening tool into the small crack between the screen and back panel. Gently pry open the tablet.
  2. Acer Iconia One 8 Battery Replacement: adım 2, 1 resimden 1.
    • Remove the black piece of tape that is holding the red, yellow, and white wires in place.
  3. Acer Iconia One 8 Battery Replacement: adım 3, 1 resimden 1.
    • Once the tape has been removed, gently pinch the wires and remove them from the socket. They should come out easily.
  4. Acer Iconia One 8 Battery Replacement: adım 4, 1 resimden 1.
    • Carefully work a plastic spudger underneath the battery and pry it free.
    • Use an iOpener or carefully apply heat with a heat gun to soften the adhesive under the battery.
    • Be careful not to bend or puncture the battery.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Josh Cooper
319 İtibar
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 10
Her zaman: 2,848
