Ana içeriğe geç
Acer Iconia Tab 8 A1-860 Motherboard Replacement
Neye ihtiyacın var
  1. Acer Iconia Tab 8 A1-860 Motherboard Replacement, Rear Case: adım 1, 2 resimden 1. Acer Iconia Tab 8 A1-860 Motherboard Replacement, Rear Case: adım 1, 2 resimden 2.
    • Insert the plastic opening tool into the seam between the back case and the display.
    • Work the plastic opening tool around the seam until the rear case separates from the display.
  2. Acer Iconia Tab 8 A1-860 Motherboard Replacement: adım 2, 1 resimden 1.
    • Separate the rear case and place the tablet face side down.
  3. Acer Iconia Tab 8 A1-860 Motherboard Replacement, Battery: adım 3, 1 resimden 1.
    • Using a spudger, work the tool under the battery connector located above the battery on the left side, and lift it free.
  4. Acer Iconia Tab 8 A1-860 Motherboard Replacement: adım 4, 3 resimden 1. Acer Iconia Tab 8 A1-860 Motherboard Replacement: adım 4, 3 resimden 2. Acer Iconia Tab 8 A1-860 Motherboard Replacement: adım 4, 3 resimden 3.
    • Pull firmly on the black tabs, located at the top left and bottom right of the battery.
    • The clear adhesive strips attached to the tabs are quite stretchy. Don't give up; keep pulling the tabs until the battery releases. The strips will not be reusable.
    • Remove the battery.
  5. Acer Iconia Tab 8 A1-860 Motherboard Replacement, Motherboard: adım 5, 2 resimden 1. Acer Iconia Tab 8 A1-860 Motherboard Replacement, Motherboard: adım 5, 2 resimden 2.
    • Using the spudger, remove the two tabs shown by placing the spudger under the gray part of the connectors and pulling on the tabs.
  6. Acer Iconia Tab 8 A1-860 Motherboard Replacement: adım 6, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove the three 2 mm screws.
  7. Acer Iconia Tab 8 A1-860 Motherboard Replacement: adım 7, 2 resimden 1. Acer Iconia Tab 8 A1-860 Motherboard Replacement: adım 7, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Using the spudger, push the tab where this belt connects to the motherboard to free it.
    • Use tweezers in order to pull the belt from its slot in the motherboard.
  8. Acer Iconia Tab 8 A1-860 Motherboard Replacement: adım 8, 2 resimden 1. Acer Iconia Tab 8 A1-860 Motherboard Replacement: adım 8, 2 resimden 2.
    • Using the spudger, push the tab connecting this belt to the motherboard.
    • Once the tab is pushed and the belt is free to move, use tweezers to pull it from the slot.
  9. Acer Iconia Tab 8 A1-860 Motherboard Replacement: adım 9, 3 resimden 1. Acer Iconia Tab 8 A1-860 Motherboard Replacement: adım 9, 3 resimden 2. Acer Iconia Tab 8 A1-860 Motherboard Replacement: adım 9, 3 resimden 3.
    • Using tweezers, pull upward on the end of this belt where it plugs into the motherboard.
  10. Acer Iconia Tab 8 A1-860 Motherboard Replacement: adım 10, 3 resimden 1. Acer Iconia Tab 8 A1-860 Motherboard Replacement: adım 10, 3 resimden 2. Acer Iconia Tab 8 A1-860 Motherboard Replacement: adım 10, 3 resimden 3.
    • With the tweezers, grab the gray wire and move it from underneath the plastic piece shown in red.
    • Then place the tweezers on the end of the wire circled, and pull the piece from the motherboard.
  11. Acer Iconia Tab 8 A1-860 Motherboard Replacement: adım 11, 3 resimden 1. Acer Iconia Tab 8 A1-860 Motherboard Replacement: adım 11, 3 resimden 2. Acer Iconia Tab 8 A1-860 Motherboard Replacement: adım 11, 3 resimden 3.
    • Use tweezers in order to lift a corner of this copper foil.
    • Then use a spudger to pull the copper foil from the motherboard.
    • If the copper foil does not remove easily, use an iOpener heating pad to release the adhesive.
  12. Acer Iconia Tab 8 A1-860 Motherboard Replacement: adım 12, 2 resimden 1. Acer Iconia Tab 8 A1-860 Motherboard Replacement: adım 12, 2 resimden 2.
    • Using tweezers, remove the "void" sticker to reveal a 3 mm screw.
    • Use a Phillips #000 screwdriver to remove the three 3 mm screws.
  13. Acer Iconia Tab 8 A1-860 Motherboard Replacement: adım 13, 2 resimden 1. Acer Iconia Tab 8 A1-860 Motherboard Replacement: adım 13, 2 resimden 2.
    • Carefully lift the motherboard out of its slot in the rear case.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Michael Buchanan
361 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team S2-G3, Harley Spring 2019 IUPUI, Team S2-G3, Harley Spring 2019 üyesi
IUPUI-HARLEY-S19S2G3
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 11
Her zaman: 436
