Giriş
The Acer Iconia Tab uses a Li-Po 3260 mAh battery that is screwed into the device.
Neye ihtiyacın var
With the plastic opening tool pry open the grey plastic siding on both sides of the tablet.
Bir başkası bu kılavuzu tamamladı.
2 Yorum
Instructions should point out that when removing the device from the case that prying tool must got between the gasket and plastic case, NOT between the screen and the gasket. I hope my cracked screen will still work!
What are the specifications to purchase a new battery for my icona Acer tablet 200 ?
