Ana içeriğe geç
Acer Iconia Tab A200 Battery Replacement
Neye ihtiyacın var
  1. Acer Iconia Tab A200 Battery Replacement, Battery: adım 1, 2 resimden 1. Acer Iconia Tab A200 Battery Replacement, Battery: adım 1, 2 resimden 2.
    • With the plastic opening tool pry open the grey plastic siding on both sides of the tablet.
  2. Acer Iconia Tab A200 Battery Replacement: adım 2, 2 resimden 1. Acer Iconia Tab A200 Battery Replacement: adım 2, 2 resimden 2.
    • Using a Phillips #00 screwdriver remove the 4.0 mm screws on the sides of the tablet.
    • There are two screws on each side of the tablet that need to be removed before the back casing can be removed.
  3. Acer Iconia Tab A200 Battery Replacement: adım 3, 2 resimden 1. Acer Iconia Tab A200 Battery Replacement: adım 3, 2 resimden 2.
    • Once the 4 screws have been removed use the plastic opening tool to pry open the device on the side of the device.
    • Be careful prying on the sides where you removed the screw as the plastic casing is not very strong and may break.
    • After prying open the case with the plastic opening tool carefully remove the case from the device and place the device face down on its screen.
  4. Acer Iconia Tab A200 Battery Replacement: adım 4, 2 resimden 1. Acer Iconia Tab A200 Battery Replacement: adım 4, 2 resimden 2.
    • Using a Phillips #00 screwdriver remove the 4.0 mm screws holding the battery in place.
  5. Acer Iconia Tab A200 Battery Replacement: adım 5, 2 resimden 1. Acer Iconia Tab A200 Battery Replacement: adım 5, 2 resimden 2.
    • Lift the battery out of the device, and disconnect the cable attached to the motherboard by pulling it out to the side not lifting it up.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jaimie Payne
477 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 5-5, Landers Spring 2016 UMass Dartmouth, Team 5-5, Landers Spring 2016 üyesi
UMASSD-LANDERS-S16S5G5
3 Üyeler
6 adet Kılavuz yazıldı
2 Yorum
Instructions should point out that when removing the device from the case that prying tool must got between the gasket and plastic case, NOT between the screen and the gasket. I hope my cracked screen will still work!
Michael Burlovich - Yanıt
What are the specifications to purchase a new battery for my icona Acer tablet 200 ?
Gloria Regester - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 15
Her zaman: 1,792
