Ana içeriğe geç
Acer Iconia Tab A200 Screen Replacement
Neye ihtiyacın var
  1. Acer Iconia Tab A200 Screen Replacement, Battery: adım 1, 2 resimden 1. Acer Iconia Tab A200 Screen Replacement, Battery: adım 1, 2 resimden 2.
    • With the plastic opening tool pry open the grey plastic siding on both sides of the tablet.
    FixBot'a Sor
    Yorum Ekle
  2. Acer Iconia Tab A200 Screen Replacement: adım 2, 2 resimden 1. Acer Iconia Tab A200 Screen Replacement: adım 2, 2 resimden 2.
    • Using a Phillips #00 screwdriver remove the 4.0 mm screws on the sides of the tablet.
    • There are two screws on each side of the tablet that need to be removed before the back casing can be removed.
    FixBot'a Sor
    Yorum Ekle
  3. Acer Iconia Tab A200 Screen Replacement: adım 3, 2 resimden 1. Acer Iconia Tab A200 Screen Replacement: adım 3, 2 resimden 2.
    • Once the 4 screws have been removed use the plastic opening tool to pry open the device on the side of the device.
    • Be careful prying on the sides where you removed the screw as the plastic casing is not very strong and may break.
    • After prying open the case with the plastic opening tool carefully remove the case from the device and place the device face down on its screen.
    FixBot'a Sor
    Yorum Ekle
  4. Acer Iconia Tab A200 Screen Replacement: adım 4, 2 resimden 1. Acer Iconia Tab A200 Screen Replacement: adım 4, 2 resimden 2.
    • Using a Phillips #00 screwdriver remove the 4.0 mm screws holding the battery in place.
    FixBot'a Sor
    Yorum Ekle
  5. Acer Iconia Tab A200 Screen Replacement: adım 5, 2 resimden 1. Acer Iconia Tab A200 Screen Replacement: adım 5, 2 resimden 2.
    • Lift the battery out of the device, and disconnect the cable attached to the motherboard by pulling it out to the side not lifting it up.
    FixBot'a Sor
    Yorum Ekle
  6. Acer Iconia Tab A200 Screen Replacement, DC Power Jack Component: adım 6, 1 resimden 1.
    • Using the plastic opening tool gently lift up the charging component out of its slot in the case.
    FixBot'a Sor
    Yorum Ekle
  7. Acer Iconia Tab A200 Screen Replacement: adım 7, 1 resimden 1.
    • Continue to lift up the cord until it is free from the case and only attached to the motherboard.
    • You may need to continue using the plastic opening tool to lift the cord out of the case due to limited hand space.
    FixBot'a Sor
    Yorum Ekle
  8. Acer Iconia Tab A200 Screen Replacement: adım 8, 1 resimden 1.
    • Disconnect the power component from the motherboard by pulling it out horizontally. Do not pull up on the cord only pull out
    FixBot'a Sor
    Yorum Ekle
  9. Acer Iconia Tab A200 Screen Replacement, Microphone: adım 9, 2 resimden 1. Acer Iconia Tab A200 Screen Replacement, Microphone: adım 9, 2 resimden 2.
    • Lift up on the microphone cable to lift the microphone component away from the case.
    FixBot'a Sor
    Yorum Ekle
  10. Acer Iconia Tab A200 Screen Replacement: adım 10, 1 resimden 1.
    • Once the microphone has been lifted away from the case, disconnect the microphone cable from the motherboard by pulling the cable out horizontally. Do not lift up to remove.
    FixBot'a Sor
    Yorum Ekle
  11. Acer Iconia Tab A200 Screen Replacement, Speaker: adım 11, 2 resimden 1. Acer Iconia Tab A200 Screen Replacement, Speaker: adım 11, 2 resimden 2.
    • After removing the battery use a Phillips head #00 screwdriver to remove the 3.0 mm screws holding the dual speakers in place.
    FixBot'a Sor
    Yorum Ekle
  12. Acer Iconia Tab A200 Screen Replacement: adım 12, 1 resimden 1.
    • Once the screws are removed, lift up on the speakers to remove them from the case.
    FixBot'a Sor
    Yorum Ekle
  13. Acer Iconia Tab A200 Screen Replacement: adım 13, 1 resimden 1.
    • Once you have removed the speakers from the case, disconnect the speakers from the motherboard by pulling the cable out horizontally. Do not pull up on the cable.
    FixBot'a Sor
    Yorum Ekle
  14. Acer Iconia Tab A200 Screen Replacement, Motherboard: adım 14, 1 resimden 1.
    • Using the plastic opening tool unplug the green cable by placing the tool under where the cable meets the plug and lifting up.
    • After unplugging the green cable remove the black tape that secures the green cable to motherboard.
    • Only unplug the end connected to the motherboard. Do not disconnect the soldered end of the cable.
    FixBot'a Sor
    Yorum Ekle
  15. Acer Iconia Tab A200 Screen Replacement: adım 15, 1 resimden 1.
    • Using the plastic opening tool unplug the black cable by placing the tool under where the cable meets the plug and lift up.
    FixBot'a Sor
    Yorum Ekle
  16. Acer Iconia Tab A200 Screen Replacement: adım 16, 2 resimden 1. Acer Iconia Tab A200 Screen Replacement: adım 16, 2 resimden 2.
    • Once all cables have been disconnected from the motherboard, remove the seven remaining 3.0 mm screws with a Phillips head screwdriver size #00.
    • After the screws have been removed lift up on the motherboard to remove it from the case.
    • If you feel any pull when removing the motherboard, check to see if you did not disconnect a cable connected to the board.
    FixBot'a Sor
    Yorum Ekle
  17. Acer Iconia Tab A200 Screen Replacement, Screen: adım 17, 2 resimden 1. Acer Iconia Tab A200 Screen Replacement, Screen: adım 17, 2 resimden 2.
    • Using the pointed tip of the nylon spudger, pry the unit board off the case
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but the regular black nylon spudger or a plastic opening tool should be used whenever possible.
    FixBot'a Sor
    Yorum Ekle
  18. Acer Iconia Tab A200 Screen Replacement: adım 18, 1 resimden 1.
    • Flip the device over, so that the screen is face up.
    • Using the metal spudgers pry apart and separate the screen from the device.
    • Be careful when using the metal spudger as it may damage the device.
    • You may need to use several spudgers or opening tools to keep the screen seperated as you continue to pry the screen away from the device.
    FixBot'a Sor
    Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Steve Chiu
253 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 5-5, Landers Spring 2016 UMass Dartmouth, Team 5-5, Landers Spring 2016 üyesi
UMASSD-LANDERS-S16S5G5
3 Üyeler
6 adet Kılavuz yazıldı
2Kılavuz Yorumları
Looking forward to fixing this tablet a friend had given up on then gave to me. So funny how easily ppl give up!Thank you for this spectacular set of directions. Looks like it will be the one that works for the tablet I have.
MichelleE1 - Yanıt Paylaş
how can i tell if there is any water damage?
Samuel Gentry - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 35
Her zaman: 2,012
