Ana içeriğe geç
Giriş
Replace the speaker in your Acer Iconia Tab 500.
Parçalar
Hiçbir parça belirtilmedi.
  1. To start, gently separate one corner of the case using the black spudger.
    • To start, gently separate one corner of the case using the black spudger.
  2. Once you have successfully pried the spudger in between the front case and back case, continue do so around the entire tablet until the back case is completely disconnected.
    • Once you have successfully pried the spudger in between the front case and back case, continue do so around the entire tablet until the back case is completely disconnected.
  3. Locate the 4 screws and cable that hold in the two speakers.
    • Locate the 4 screws and cable that hold in the two speakers.
    • Use the Phillips #1 screwdriver to remove these 2mm black screws.
    • Remove the 2mm silver screws.
    • Not all 4 screws are going to be the same kind. This will not affect the speaker replacement.
  4. Carefully remove the connector cable by pushing on the rim of black plastic insert. Carefully remove the connector cable by pushing on the rim of black plastic insert.
    • Carefully remove the connector cable by pushing on the rim of black plastic insert.
  5. Unfortunately, the top speaker is a wedged under the motherboard.
    • Unfortunately, the top speaker is a wedged under the motherboard.
    • To get this speaker out, use the spudger and gently pry it out.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Kyle Libby
1.000 İtibar
7 adet Kılavuz yazıldı
Takım
Cal Poly, Team 7-23, Regan Spring 2014 Cal Poly, Team 7-23, Regan Spring 2014 üyesi
CPSU-REGAN-S14S7G23
4 Üyeler
18 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 1,862
