Ana içeriğe geç
Parçalar
Hiçbir parça belirtilmedi.
  1. To start, gently separate one corner of the case using the black spudger.
    • To start, gently separate one corner of the case using the black spudger.
  2. Once you have successfully pried the spudger in between the front case and back case, continue do so around the entire tablet until the back case is completely disconnected.
    • Once you have successfully pried the spudger in between the front case and back case, continue do so around the entire tablet until the back case is completely disconnected.
  3. Remove the 5mm screws that are securing the battery to the rest of the tablet.
    • Remove the 5mm screws that are securing the battery to the rest of the tablet.
    • Use the Phillips #00 Screwdriver to remove the 5mm screws.
  4. Use the sharper end of the spudger to disconnect the battery from the mother board.
    • Use the sharper end of the spudger to disconnect the battery from the mother board.
    • The battery connector will slide off.
  5. After setting aside the battery, remove the two 5mm screws holding the metal plate over the USB port.
    • After setting aside the battery, remove the two 5mm screws holding the metal plate over the USB port.
  6. Find and remove the silver 5mm screw holding down the metal cover opposite the USB port.
    • Find and remove the silver 5mm screw holding down the metal cover opposite the USB port.
  7. Disconnect the blue cable by gently lifting the flap.
    • Disconnect the blue cable by gently lifting the flap.
    • Remove the indicated 2mm screw holding the speaker in place.
  8. Pull up the metal panel just enough to allow access, then remove the USB port.
    • Pull up the metal panel just enough to allow access, then remove the USB port.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Sam Macy
1.149 İtibar
1 Kılavuz yazıldı
Takım
Cal Poly, Team 7-23, Regan Spring 2014 Cal Poly, Team 7-23, Regan Spring 2014 üyesi
CPSU-REGAN-S14S7G23
4 Üyeler
18 adet Kılavuz yazıldı
Bir Yorum
Awesome I love the visual of the steps. Thank you!
_Samsunz
samiam6 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 3,309
