Giriş
Batteries tend to lose capacity over time as they are used and eventually fail. If your battery won’t hold a charge or can’t power your device, you may decide to replace the battery. This guide will demonstrate battery replacement for the Acer Iconia Tab A501.
Neye ihtiyacın var
Use a plastic opening tool to carefully separate the back cover, starting at the volume buttons.
Continue separating the back cover along the short side closest to the camera and around the device.
Bu adımda kullanılan alet:Tweezers$3.99
Use the angled tweezers to disconnect the white motherboard-battery connector in the middle of the side opposite the docking port.
Bir başkası bu kılavuzu tamamladı.
