Ana içeriğe geç
Acer Iconia Tab B1 Factory Hard Reset/Password Removal
Videoya Genel Bakış
  1. Acer Iconia Tab B1 Factory Hard Reset/Password Removal, Acer Iconia Tab B1 Factory Hard Reset/Password Removal: adım 1, 3 resimden 1. Acer Iconia Tab B1 Factory Hard Reset/Password Removal, Acer Iconia Tab B1 Factory Hard Reset/Password Removal: adım 1, 3 resimden 2. Acer Iconia Tab B1 Factory Hard Reset/Password Removal, Acer Iconia Tab B1 Factory Hard Reset/Password Removal: adım 1, 3 resimden 3.
    • From the reset hole we can make reset without erasing data.
  2. Acer Iconia Tab B1 Factory Hard Reset/Password Removal: adım 2, 3 resimden 1. Acer Iconia Tab B1 Factory Hard Reset/Password Removal: adım 2, 3 resimden 2. Acer Iconia Tab B1 Factory Hard Reset/Password Removal: adım 2, 3 resimden 3.
    • Power of the tablet. Push and hold Vol(+) and Power On keys together in the same time.
  3. Acer Iconia Tab B1 Factory Hard Reset/Password Removal: adım 3, 2 resimden 1. Acer Iconia Tab B1 Factory Hard Reset/Password Removal: adım 3, 2 resimden 2.
    • Now you are in the Boot Mode menu. With Vol(+), (-) go to [SD Update Image Mode] and select it with Power On key.
    • Pressing the Power On key too quickly may turn off the tablet screen. You'll need to press and hold for about a second to select [SD Update Image Mode].
    Hi when i make it, fastboot mode was in the screen
    Sihem Smiti - Yanıt
  4. Acer Iconia Tab B1 Factory Hard Reset/Password Removal: adım 4, 3 resimden 1. Acer Iconia Tab B1 Factory Hard Reset/Password Removal: adım 4, 3 resimden 2. Acer Iconia Tab B1 Factory Hard Reset/Password Removal: adım 4, 3 resimden 3.
    • Now you are in Android System Recovery Menu. Choose "wipe data / factory reset", "Yes -- delete all user data". And finally "reboot system now".
  5. Acer Iconia Tab B1 Factory Hard Reset/Password Removal: adım 5, 3 resimden 1. Acer Iconia Tab B1 Factory Hard Reset/Password Removal: adım 5, 3 resimden 2. Acer Iconia Tab B1 Factory Hard Reset/Password Removal: adım 5, 3 resimden 3.
    • After restart you will have empty (free of data) device and access to it.
    buen dia la tablet se queda en la pantalla de welcome que hago
    Frank Rondon - Yanıt
Sonuç
11 farklı kişi bu kılavuzu tamamladı.
ZFix
191.368 İtibar
330 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
322 Üyeler
2.545 adet Kılavuz yazıldı
2 Yorum
I have a problem when it came to SD image update mode I get the log acer restarts does not pass the second part you have any idea?
tengo un problema cuando entró a SD image update mode me sale el log de acer se reinicia no pasa a la segunda parte tienes alguna idea ?
martinez1816 - Yanıt
I have the same problem when it came to SD image update mode I get the acer logo and it restarts it does not pass to the android logo it geast restart
Claudiu - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 26
Her zaman: 70,708
