Ana içeriğe geç
Acer Nitro 5 AN515-53-52FA Battery Replacement
Neye ihtiyacın var
  1. Acer Nitro 5 AN515-53-52FA Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Before starting the replacement, make sure the laptop is turned off and unplugged.
    • Flip the laptop upside down so that the bottom is facing up.
  2. Acer Nitro 5 AN515-53-52FA Battery Replacement: adım 2, 2 resimden 1. Acer Nitro 5 AN515-53-52FA Battery Replacement: adım 2, 2 resimden 2.
    • Use the Phillips #0 screwdriver to unscrew the sixteen 9 mm screws holding the back cover in place.
  3. Acer Nitro 5 AN515-53-52FA Battery Replacement: adım 3, 2 resimden 1. Acer Nitro 5 AN515-53-52FA Battery Replacement: adım 3, 2 resimden 2.
    • Use the opening pick to work your way around the edges to remove the bottom case carefully.
    • Do not try to put too much force on the shell off as you may damage it.
  4. Acer Nitro 5 AN515-53-52FA Battery Replacement: adım 4, 1 resimden 1.
    • Use the Phillips #0 screwdriver to unscrew the four 9 mm screws holding the battery in place.
  5. Acer Nitro 5 AN515-53-52FA Battery Replacement: adım 5, 2 resimden 1. Acer Nitro 5 AN515-53-52FA Battery Replacement: adım 5, 2 resimden 2.
    • Disconnect the battery's motherboard connector with your fingers.
  6. Acer Nitro 5 AN515-53-52FA Battery Replacement: adım 6, 2 resimden 1. Acer Nitro 5 AN515-53-52FA Battery Replacement: adım 6, 2 resimden 2.
    • Lift the battery up and out of the laptop.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Alfredo Prieto
827 İtibar
5 adet Kılavuz yazıldı
Ekip
Gateway, Team 1-3, Pee Fall 2022 Gateway, Team 1-3, Pee Fall 2022 üyesi
GCC-PEE-F22S1G3
4 Üyeler
7 adet Kılavuz yazıldı
2 Yorum
Do I have to use other material to put the bottom case back on or is it easy to do by hand?
SomeDude372 - Yanıt
Can I use a Jimmy instead of the opening picks?
SomeDude372 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 42
Son 30 gün: 150
Her zaman: 1,231
