Ana içeriğe geç
Acer Nitro 5 AN515-53-52FA CMOS Replacement
Neye ihtiyacın var
  1. Acer Nitro 5 AN515-53-52FA CMOS Replacement, Battery: adım 1, 1 resimden 1.
    • Before starting the replacement, make sure the laptop is turned off and unplugged.
    • Flip the laptop upside down so that the bottom is facing up.
  2. Acer Nitro 5 AN515-53-52FA CMOS Replacement: adım 2, 2 resimden 1. Acer Nitro 5 AN515-53-52FA CMOS Replacement: adım 2, 2 resimden 2.
    • Use the Phillips #0 screwdriver to unscrew the sixteen 9 mm screws holding the back cover in place.
  3. Acer Nitro 5 AN515-53-52FA CMOS Replacement: adım 3, 2 resimden 1. Acer Nitro 5 AN515-53-52FA CMOS Replacement: adım 3, 2 resimden 2.
    • Use the opening pick to work your way around the edges to remove the bottom case carefully.
    • Do not try to put too much force on the shell off as you may damage it.
  4. Acer Nitro 5 AN515-53-52FA CMOS Replacement: adım 4, 1 resimden 1.
    • Use the Phillips #0 screwdriver to unscrew the four 9 mm screws holding the battery in place.
  5. Acer Nitro 5 AN515-53-52FA CMOS Replacement: adım 5, 2 resimden 1. Acer Nitro 5 AN515-53-52FA CMOS Replacement: adım 5, 2 resimden 2.
    • Disconnect the battery's motherboard connector with your fingers.
  6. Acer Nitro 5 AN515-53-52FA CMOS Replacement: adım 6, 2 resimden 1. Acer Nitro 5 AN515-53-52FA CMOS Replacement: adım 6, 2 resimden 2.
    • Lift the battery up and out of the laptop.
  7. Acer Nitro 5 AN515-53-52FA CMOS Replacement, CMOS: adım 7, 2 resimden 1. Acer Nitro 5 AN515-53-52FA CMOS Replacement, CMOS: adım 7, 2 resimden 2.
    • Locate the CMOS that is under the battery.
  8. Acer Nitro 5 AN515-53-52FA CMOS Replacement: adım 8, 2 resimden 1. Acer Nitro 5 AN515-53-52FA CMOS Replacement: adım 8, 2 resimden 2.
    • Gently unplug the port.
  9. Acer Nitro 5 AN515-53-52FA CMOS Replacement: adım 9, 2 resimden 1. Acer Nitro 5 AN515-53-52FA CMOS Replacement: adım 9, 2 resimden 2.
    • Carefully pull the CMOS Battery, as there is adhesive keeping it attached.
Sonuç
Alfredo Prieto
827 İtibar
5 adet Kılavuz yazıldı
Ekip
Gateway, Team 1-3, Pee Fall 2022 Gateway, Team 1-3, Pee Fall 2022 üyesi
GCC-PEE-F22S1G3
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 15
Son 7 gün: 84
Son 30 gün: 336
Her zaman: 5,394
