Ana içeriğe geç
Acer Nitro 5 AN515-53-55G9 SSD Replacement
Neye ihtiyacın var
  1. Acer Nitro 5 AN515-53-55G9 SSD Replacement, Battery: adım 1, 3 resimden 1. Acer Nitro 5 AN515-53-55G9 SSD Replacement, Battery: adım 1, 3 resimden 2. Acer Nitro 5 AN515-53-55G9 SSD Replacement, Battery: adım 1, 3 resimden 3.
    • Make sure laptop is off and unplugged before beginning replacement.
    • Flip the laptop upside down so that the bottom is facing up.
    • Identify the RAM tray on the bottom of the laptop.
  2. Acer Nitro 5 AN515-53-55G9 SSD Replacement: adım 2, 3 resimden 1. Acer Nitro 5 AN515-53-55G9 SSD Replacement: adım 2, 3 resimden 2. Acer Nitro 5 AN515-53-55G9 SSD Replacement: adım 2, 3 resimden 3.
    • Use the Phillips #0 screwdriver to remove the 9mm screw in the bottom left corner of the RAM tray covering.
    • Remove the RAM tray cover by prying up with a spudger.
  3. Acer Nitro 5 AN515-53-55G9 SSD Replacement: adım 3, 3 resimden 1. Acer Nitro 5 AN515-53-55G9 SSD Replacement: adım 3, 3 resimden 2. Acer Nitro 5 AN515-53-55G9 SSD Replacement: adım 3, 3 resimden 3.
    • Identify the Hard Drive tray to the left side of the laptop.
    • Remove screw with a #0 Philips screwdriver.
    • Lift up the Slot covering using a spunger.
  4. Acer Nitro 5 AN515-53-55G9 SSD Replacement: adım 4, 1 resimden 1.
    • Use the Phillips #0 screwdriver to remove the 9mm screws holding the back cover in place.
    • Remove the screws from the hard drive and remove it from the device.
  5. Acer Nitro 5 AN515-53-55G9 SSD Replacement: adım 5, 3 resimden 1. Acer Nitro 5 AN515-53-55G9 SSD Replacement: adım 5, 3 resimden 2. Acer Nitro 5 AN515-53-55G9 SSD Replacement: adım 5, 3 resimden 3.
    • Be sure you removed the hard drive. when you open the back shell and hard drive is built in this may cause damage to cable and other components.
    • Carefully remove the back shell from the device working your way around all the edges.
    • Do not forcefully try to separate the shell as you may cause harm to the shell.
  6. Acer Nitro 5 AN515-53-55G9 SSD Replacement: adım 6, 2 resimden 1. Acer Nitro 5 AN515-53-55G9 SSD Replacement: adım 6, 2 resimden 2.
    • Removing the back shell of the computer and it will look like this.
    • The battery for the device is located at the bottom middle of the laptop at this orientation.
  7. Acer Nitro 5 AN515-53-55G9 SSD Replacement: adım 7, 3 resimden 1. Acer Nitro 5 AN515-53-55G9 SSD Replacement: adım 7, 3 resimden 2. Acer Nitro 5 AN515-53-55G9 SSD Replacement: adım 7, 3 resimden 3.
    • Locate the connector of the battery to the motherboard.
    • Using your fingers, slide out the connector.
  8. Acer Nitro 5 AN515-53-55G9 SSD Replacement: adım 8, 1 resimden 1.
    • Remove battery from device.
  9. Acer Nitro 5 AN515-53-55G9 SSD Replacement, SSD: adım 9, 2 resimden 1. Acer Nitro 5 AN515-53-55G9 SSD Replacement, SSD: adım 9, 2 resimden 2.
    • Locate the SSD in the top right corner of the laptop.
  10. Acer Nitro 5 AN515-53-55G9 SSD Replacement: adım 10, 3 resimden 1. Acer Nitro 5 AN515-53-55G9 SSD Replacement: adım 10, 3 resimden 2. Acer Nitro 5 AN515-53-55G9 SSD Replacement: adım 10, 3 resimden 3.
    • Use the Phillips #0 screwdriver to remove the 3mm screw holding the SSD card in place.
    • The SSD will pop up at an angle when the screw is removed.
  11. Acer Nitro 5 AN515-53-55G9 SSD Replacement: adım 11, 1 resimden 1.
    • Slide the SSD out of its slot.
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 39
Son 30 gün: 169
Her zaman: 22,456
