Ana içeriğe geç
Acer Nitro 5 AN515-55 SSD Replacement
Neye ihtiyacın var
  1. Acer Nitro 5 AN515-55 SSD Replacement, SSD: adım 1, 1 resimden 1.
    • Shut down your laptop.
    • Make sure your laptop is completely turned off to prevent damaging other parts.
  2. Acer Nitro 5 AN515-55 SSD Replacement: adım 2, 3 resimden 1. Acer Nitro 5 AN515-55 SSD Replacement: adım 2, 3 resimden 2. Acer Nitro 5 AN515-55 SSD Replacement: adım 2, 3 resimden 3.
    • Flip the laptop on its back.
    • Remove the eleven 8 mm screws securing the back cover using the Phillips #1 screwdriver.
  3. Acer Nitro 5 AN515-55 SSD Replacement: adım 3, 2 resimden 1. Acer Nitro 5 AN515-55 SSD Replacement: adım 3, 2 resimden 2.
    • Loosen the back cover using a plastic opening tool.
  4. Acer Nitro 5 AN515-55 SSD Replacement: adım 4, 2 resimden 1. Acer Nitro 5 AN515-55 SSD Replacement: adım 4, 2 resimden 2.
    • Pull the back cover off and put it in a safe place.
    • A little bit of force is needed to pry open the clips at the corners of the laptop.
  5. Acer Nitro 5 AN515-55 SSD Replacement: adım 5, 3 resimden 1. Acer Nitro 5 AN515-55 SSD Replacement: adım 5, 3 resimden 2. Acer Nitro 5 AN515-55 SSD Replacement: adım 5, 3 resimden 3.
    • Remove the 2.6 mm screw that is holding down the SSD with a Phillips #0 screwdriver.
    • Make sure to ground yourself before working on the motherboard to prevent damage.
  6. Acer Nitro 5 AN515-55 SSD Replacement: adım 6, 3 resimden 1. Acer Nitro 5 AN515-55 SSD Replacement: adım 6, 3 resimden 2. Acer Nitro 5 AN515-55 SSD Replacement: adım 6, 3 resimden 3.
    • Gently pull out the damaged SSD.
  7. Acer Nitro 5 AN515-55 SSD Replacement: adım 7, 2 resimden 1. Acer Nitro 5 AN515-55 SSD Replacement: adım 7, 2 resimden 2.
    • Slide in the new SSD.
    • Screw it in place.
  8. Acer Nitro 5 AN515-55 SSD Replacement: adım 8, 2 resimden 1. Acer Nitro 5 AN515-55 SSD Replacement: adım 8, 2 resimden 2.
    • Put the back cover on and gently snap the clips back in.
    • Screw the back cover in place.
Sonuç
Follow the guide that comes with your new SSD to make sure your laptop recognizes your new SSD.
6 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
This model is supposed to have 3 slots 2 for SSD and 1 for HDD, can you please point them out? Just add an extra SDD?
mayumidb - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 54
Son 30 gün: 276
Her zaman: 9,697
