Giriş
Laptop batteries often wear out the fastest of all laptop components, resulting in lower charge capacity and battery life, or even dying entirely. This guide will show you how to safely remove the back cover and replace the battery of your Acer Nitro 5 AN515-55-55M1.
Neye ihtiyacın var
Make sure the device is off and unplugged from power.
Flip the device so the bottom is facing up.
Remove 11 screws from the bottom case using a Phillips #1 screwdriver.
Congratulations! You have successfully replaced the battery of your Acer Nitro 5 AN515-55-55M1!
2 farklı kişi bu kılavuzu tamamladı.
