Ana içeriğe geç
Acer Nitro 5 AN515-55-55M1 Fan Replacement
Neye ihtiyacın var
  1. Acer Nitro 5 AN515-55-55M1 Fan Replacement, Bottom Cover: adım 1, 1 resimden 1.
    • Make sure the device is off and unplugged from power.
    • Flip the device so the bottom is facing up.
    • Remove 11 screws from the bottom case using a Phillips #1 screwdriver.
  2. Acer Nitro 5 AN515-55-55M1 Fan Replacement: adım 2, 2 resimden 1. Acer Nitro 5 AN515-55-55M1 Fan Replacement: adım 2, 2 resimden 2.
    • Lift the top left and right corners up and away from the device.
    • This may require some force and will make harsh clicking sounds. This is normal; it's the plastic tabs separating from each other.
    • Remove the panel from the laptop.
  3. Acer Nitro 5 AN515-55-55M1 Fan Replacement, Battery: adım 3, 3 resimden 1. Acer Nitro 5 AN515-55-55M1 Fan Replacement, Battery: adım 3, 3 resimden 2. Acer Nitro 5 AN515-55-55M1 Fan Replacement, Battery: adım 3, 3 resimden 3.
    • Use an opening tool to disconnect the battery from the motherboard.
  4. Acer Nitro 5 AN515-55-55M1 Fan Replacement: adım 4, 2 resimden 1. Acer Nitro 5 AN515-55-55M1 Fan Replacement: adım 4, 2 resimden 2.
    • Remove the two screws from the battery with a Phillips #1 screwdriver.
    • Remove the battery by pulling up and out from the left side.
  5. Acer Nitro 5 AN515-55-55M1 Fan Replacement, Motherboard: adım 5, 3 resimden 1. Acer Nitro 5 AN515-55-55M1 Fan Replacement, Motherboard: adım 5, 3 resimden 2. Acer Nitro 5 AN515-55-55M1 Fan Replacement, Motherboard: adım 5, 3 resimden 3.
    • Disconnect the seven cables from the motherboard using an iFixit opening tool.
  6. Acer Nitro 5 AN515-55-55M1 Fan Replacement: adım 6, 3 resimden 1. Acer Nitro 5 AN515-55-55M1 Fan Replacement: adım 6, 3 resimden 2. Acer Nitro 5 AN515-55-55M1 Fan Replacement: adım 6, 3 resimden 3.
    • Use an iFixit opening tool to lift the two Wi-Fi antenna cables up and away from the Wi-Fi card.
  7. Acer Nitro 5 AN515-55-55M1 Fan Replacement: adım 7, 3 resimden 1. Acer Nitro 5 AN515-55-55M1 Fan Replacement: adım 7, 3 resimden 2. Acer Nitro 5 AN515-55-55M1 Fan Replacement: adım 7, 3 resimden 3.
    • Remove the six screws surrounding the fan using a Phillips #1 screwdriver.
    • Remove the two shorter screws from the motherboard using a Phillips #1 screwdriver.
    • Lift the taped wires off of the fans on the right and left sides.
  8. Acer Nitro 5 AN515-55-55M1 Fan Replacement: adım 8, 3 resimden 1. Acer Nitro 5 AN515-55-55M1 Fan Replacement: adım 8, 3 resimden 2. Acer Nitro 5 AN515-55-55M1 Fan Replacement: adım 8, 3 resimden 3.
    • Lift up the right side of the motherboard.
    • The cables may need some guidance to leave the management holes on the motherboard.
    • Continue to lift at an angle until there is a give.
    • Remove the motherboard and fans from the laptop.
  9. Acer Nitro 5 AN515-55-55M1 Fan Replacement, Fan: adım 9, 3 resimden 1. Acer Nitro 5 AN515-55-55M1 Fan Replacement, Fan: adım 9, 3 resimden 2. Acer Nitro 5 AN515-55-55M1 Fan Replacement, Fan: adım 9, 3 resimden 3.
    • Unplug the two fan connectors from each side of the motherboard using an opening tool.
  10. Acer Nitro 5 AN515-55-55M1 Fan Replacement: adım 10, 2 resimden 1. Acer Nitro 5 AN515-55-55M1 Fan Replacement: adım 10, 2 resimden 2.
    • Both fans are loose at this point and are only being held in by thermal tape.
    • Lift both fans up on each side and fold over the heat pipe.
  11. Acer Nitro 5 AN515-55-55M1 Fan Replacement: adım 11, 2 resimden 1. Acer Nitro 5 AN515-55-55M1 Fan Replacement: adım 11, 2 resimden 2.
    • Pull the fan away from the heat pipe on both sides of the motherboard.
    • The tape will separate off of the heat pipe.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Samuel Rouillard
674 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-4, Mellen Spring 2022 UMass Dartmouth, Team 1-4, Mellen Spring 2022 üyesi
UMASSD-MELLEN-S22S1G4
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 10
Son 30 gün: 41
Her zaman: 1,168
