Ana içeriğe geç
Acer Nitro 5 AN515-55-55M1 SSD Replacement
Neye ihtiyacın var
  1. Acer Nitro 5 AN515-55-55M1 SSD Replacement, Bottom Cover: adım 1, 1 resimden 1.
    • Make sure the device is off and unplugged from power.
    • Flip the device so the bottom is facing up.
    • Remove 11 screws from the bottom case using a Phillips #1 screwdriver.
  2. Acer Nitro 5 AN515-55-55M1 SSD Replacement: adım 2, 2 resimden 1. Acer Nitro 5 AN515-55-55M1 SSD Replacement: adım 2, 2 resimden 2.
    • Lift the top left and right corners up and away from the device.
    • This may require some force and will make harsh clicking sounds. This is normal; it's the plastic tabs separating from each other.
    • Remove the panel from the laptop.
  3. Acer Nitro 5 AN515-55-55M1 SSD Replacement, SSD: adım 3, 3 resimden 1. Acer Nitro 5 AN515-55-55M1 SSD Replacement, SSD: adım 3, 3 resimden 2. Acer Nitro 5 AN515-55-55M1 SSD Replacement, SSD: adım 3, 3 resimden 3.
    • Remove the single screw from the SSD using a Phillips #1 screwdriver.
  4. Acer Nitro 5 AN515-55-55M1 SSD Replacement: adım 4, 3 resimden 1. Acer Nitro 5 AN515-55-55M1 SSD Replacement: adım 4, 3 resimden 2. Acer Nitro 5 AN515-55-55M1 SSD Replacement: adım 4, 3 resimden 3.
    • The drive will lift itself up.
    • Gently pull the drive to the left to remove it from the laptop.
Sonuç
Samuel Rouillard
674 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-4, Mellen Spring 2022 UMass Dartmouth, Team 1-4, Mellen Spring 2022 üyesi
UMASSD-MELLEN-S22S1G4
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 17
Son 30 gün: 64
Her zaman: 1,525
