Ana içeriğe geç
Acer Nitro 5 AN515-55-55M1 Track Pad Replacement
Neye ihtiyacın var
  1. Acer Nitro 5 AN515-55-55M1 Track Pad Replacement, Track Pad: adım 1, 2 resimden 1. Acer Nitro 5 AN515-55-55M1 Track Pad Replacement, Track Pad: adım 1, 2 resimden 2.
    • Turn the laptop over so its underside is up.
    • Use a Phillips #0 screwdriver to remove all 7 mm screws from the bottom cover.
    • Pop the cover off around the edges.
  2. Acer Nitro 5 AN515-55-55M1 Track Pad Replacement: adım 2, 2 resimden 1. Acer Nitro 5 AN515-55-55M1 Track Pad Replacement: adım 2, 2 resimden 2.
    • Remove the adhesive from the battery.
    • Use a Phillips #0 screwdriver to remove the two 5 mm screws.
  3. Acer Nitro 5 AN515-55-55M1 Track Pad Replacement: adım 3, 1 resimden 1.
    • Remove the ribbons.
  4. Acer Nitro 5 AN515-55-55M1 Track Pad Replacement: adım 4, 2 resimden 1. Acer Nitro 5 AN515-55-55M1 Track Pad Replacement: adım 4, 2 resimden 2.
    • Use a Phillips #0 screwdriver to remove the two 3 mm screws.
    • Pull the touchpad up and out of the computer.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 20
Son 30 gün: 65
Her zaman: 954
