Ana içeriğe geç
Acer Nitro 5 AN515-57 RAM Replacement
Neye ihtiyacın var
  1. Acer Nitro 5 AN515-57 RAM Replacement, RAM: adım 1, 2 resimden 1. Acer Nitro 5 AN515-57 RAM Replacement, RAM: adım 1, 2 resimden 2.
    • Shut-down your laptop and unplug the battery connection.
    • Remove any other device attached to the laptop.
  2. Acer Nitro 5 AN515-57 RAM Replacement: adım 2, 1 resimden 1.
    • Remove eleven screws from the bottom case of the laptop using a Phillips #00 screwdriver.
  3. Acer Nitro 5 AN515-57 RAM Replacement: adım 3, 2 resimden 1. Acer Nitro 5 AN515-57 RAM Replacement: adım 3, 2 resimden 2.
    • Slide an iFixit opening tool into the front lip of the laptop and slowly move your way around the chassis.
    • Make sure not to slide the tool too deep as it can damage the board.
  4. Acer Nitro 5 AN515-57 RAM Replacement: adım 4, 2 resimden 1. Acer Nitro 5 AN515-57 RAM Replacement: adım 4, 2 resimden 2.
    • Disconnect the battery by either using the iFixit opening tool or your fingers.
  5. Acer Nitro 5 AN515-57 RAM Replacement: adım 5, 3 resimden 1. Acer Nitro 5 AN515-57 RAM Replacement: adım 5, 3 resimden 2. Acer Nitro 5 AN515-57 RAM Replacement: adım 5, 3 resimden 3.
    • Use your fingers to pull the silver latches on either side of the RAM away from each other.
    • The RAM will pop up by a few centimeters.
    • Remove the RAM from the laptop.
  6. Acer Nitro 5 AN515-57 RAM Replacement: adım 6, 1 resimden 1.
    • Reconnect the battery pins
    • While reconnecting the battery, try not to touch the metal prongs.
  7. Acer Nitro 5 AN515-57 RAM Replacement: adım 7, 2 resimden 1. Acer Nitro 5 AN515-57 RAM Replacement: adım 7, 2 resimden 2.
    • Place the back panel on to your laptop and gently press on it until it snaps in place.
    • Screw the back panel back in.
    • When turning on your laptop the first time after installing new RAM, it may take the laptop a few minutes to turn on.
Bitiş Çizgisi
4 farklı kişi bu kılavuzu tamamladı.
Hanzala Mir
242 İtibar
1 Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 32
Son 30 gün: 308
Her zaman: 6,442
