Ana içeriğe geç
Acer Nitro 5 AN517-51-56YW Battery Replacement
Neye ihtiyacın var
  1. Acer Nitro 5 AN517-51-56YW Battery Replacement, Bottom Cover: adım 1, 3 resimden 1. Acer Nitro 5 AN517-51-56YW Battery Replacement, Bottom Cover: adım 1, 3 resimden 2. Acer Nitro 5 AN517-51-56YW Battery Replacement, Bottom Cover: adım 1, 3 resimden 3.
    • Place the laptop upside-down so that the fans are facing away from you.
    • Remove the twelve 6.7 mm screws from the bottom cover using a Phillips #1 screwdriver.
    • Pry the bottom cover away from the laptop using a spudger.
  2. Acer Nitro 5 AN517-51-56YW Battery Replacement, Battery: adım 2, 2 resimden 1. Acer Nitro 5 AN517-51-56YW Battery Replacement, Battery: adım 2, 2 resimden 2.
    • Unplug the connection plug that attaches the battery to the motherboard.
    • Make sure to pull the connector safely so that it doesn't break.
    • Remove the two 4.7 mm screws using a Phillips #1 screwdriver.
  3. Acer Nitro 5 AN517-51-56YW Battery Replacement: adım 3, 2 resimden 1. Acer Nitro 5 AN517-51-56YW Battery Replacement: adım 3, 2 resimden 2.
    • Remove the battery from the laptop.
    • Make sure that your laptop powers on before you begin reassembly. If it does not start, make sure the battery is firmly connected to the motherboard.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Jacob Elkins
221 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 14
Son 30 gün: 67
Her zaman: 1,624
