Make sure that the tablet is turned off and disconnected from any power source.
Disconnect the tablet from the keyboard attachment.
If you have a Micro SD card in the tablet, remove it now.
Remove the two 3.5 mm Phillips #0 screws on either side the keyboard connection.
Starting from a corner of the tablet, use the plastic opening tool to create a gap between the screen and the back covering.
Slowly maneuver the plastic opening tool along the perimeter of the tablet to pry the screen and back covering apart.
Separate the back covering from the screen.
Use the plastic opening tool to separate the glue that holds the battery to the screen.
Remove the battery and set it aside.
20 farklı kişi bu kılavuzu tamamladı.
2 Yorum
I want a ..
Motherboard
