Giriş
Sometimes an unlabeled, broken, or missing key on your device can be replaced with new a key. This guide shows you how to replace a key with one from a manufacturer or similar device.
Neye ihtiyacın var
Make sure device is powered off and disconnected from any power supply.
Disconnect the tablet screen from the magnetic hinge where the keyboard is attached.
Pry off the damaged key by using the nylon spudger to gently push the key upwards.
2 farklı kişi bu kılavuzu tamamladı.
