Ana içeriğe geç
Acer One 10 S1003-114M Battery Replacement
Neye ihtiyacın var
  1. Acer One 10 S1003-114M Battery Replacement, Battery: adım 1, 2 resimden 1. Acer One 10 S1003-114M Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Make sure the device is turned off and disconnected from any power source.
    • To disconnect the tablet from the keyboard attachment, open the laptop and lift the tablet component up from the keyboard dock.
  2. Acer One 10 S1003-114M Battery Replacement: adım 2, 3 resimden 1. Acer One 10 S1003-114M Battery Replacement: adım 2, 3 resimden 2. Acer One 10 S1003-114M Battery Replacement: adım 2, 3 resimden 3.
    • While handling the device, make sure to avoid pushing the power button. Device must remain powered off.
    • Metal spudgers and similar prying tools can damage internal components like the motherboard. It is ideal to use a regular black nylon spudger or a plastic opening tool, but for this device the metal jimmy and spudger were the only tools that worked.
    • Starting from the corner of the tablet, use a jimmy to create a gap between the screen and the back covering.
    • Insert a metal spudger in the gap that you created with the Jimmy.
    • Slowly maneuver the metal spudger along the perimeter of the tablet to pry the screen and back covering apart.
    • Separate the back covering from the screen.
  3. Acer One 10 S1003-114M Battery Replacement: adım 3, 2 resimden 1. Acer One 10 S1003-114M Battery Replacement: adım 3, 2 resimden 2.
    • Using your hands, peel off the Polyimide tape (yellow tape).
  4. Acer One 10 S1003-114M Battery Replacement: adım 4, 3 resimden 1. Acer One 10 S1003-114M Battery Replacement: adım 4, 3 resimden 2. Acer One 10 S1003-114M Battery Replacement: adım 4, 3 resimden 3.
    • Using the Phillips #00 screwdriver, unscrew the two 2mm screws at the bottom of the tablet and open the ZIF latch.
    • Gently remove the gold ribbon cable covering the battery and set it aside.
  5. Acer One 10 S1003-114M Battery Replacement: adım 5, 2 resimden 1. Acer One 10 S1003-114M Battery Replacement: adım 5, 2 resimden 2.
    • Using the Phillips #00 screwdriver, unscrew the two 2mm screws at the top right of the battery.
  6. Acer One 10 S1003-114M Battery Replacement: adım 6, 2 resimden 1. Acer One 10 S1003-114M Battery Replacement: adım 6, 2 resimden 2.
    • Peel the three shiny black stickers from the battery (top left, bottom right, and bottom left), but keep them attached to the motherboard.
  7. Acer One 10 S1003-114M Battery Replacement: adım 7, 2 resimden 1. Acer One 10 S1003-114M Battery Replacement: adım 7, 2 resimden 2.
    • Battery is adhered to the tablet.
    • Avoid putting pressure on the glass while separating the battery from the screen.
    • Use the spudger to separate the battery from glue that holds the battery to the screen. Carefully pry the battery from the tablet.
  8. Acer One 10 S1003-114M Battery Replacement: adım 8, 1 resimden 1.
    • Remove the battery from the device.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
Where can I find the battery for this?
Ronny Merino Gonzalez - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 14
Son 30 gün: 62
Her zaman: 6,428
