Ana içeriğe geç
Acer One 10 S1003-114M Screen Hinge Replacement
Neye ihtiyacın var
  1. Acer One 10 S1003-114M Screen Hinge Replacement, Screen Hinge: adım 1, 1 resimden 1.
    • Open the screen.
  2. Acer One 10 S1003-114M Screen Hinge Replacement: adım 2, 1 resimden 1.
    • Remove the screen portion from the keyboard.
  3. Acer One 10 S1003-114M Screen Hinge Replacement: adım 3, 2 resimden 1. Acer One 10 S1003-114M Screen Hinge Replacement: adım 3, 2 resimden 2.
    • Turn over the keyboard and use the plastic opening tool to remove the two adhesive backed rubber pads furthest from the hinge.
  4. Acer One 10 S1003-114M Screen Hinge Replacement: adım 4, 3 resimden 1. Acer One 10 S1003-114M Screen Hinge Replacement: adım 4, 3 resimden 2. Acer One 10 S1003-114M Screen Hinge Replacement: adım 4, 3 resimden 3.
    • Remove the ten total screws from the back cover with a Phillips #1 screwdriver.
    • 8 screws 4.25mm in length with 4.00mm diameter heads.
    • 2 screws 6.00mm in length with 4.00mm diameter heads.
  5. Acer One 10 S1003-114M Screen Hinge Replacement: adım 5, 1 resimden 1.
    • Use the plastic opening tool to separate the front and back halves of the keyboard.
  6. Acer One 10 S1003-114M Screen Hinge Replacement: adım 6, 1 resimden 1.
    • Lift away the loosened back cover.
  7. Acer One 10 S1003-114M Screen Hinge Replacement: adım 7, 2 resimden 1. Acer One 10 S1003-114M Screen Hinge Replacement: adım 7, 2 resimden 2.
    • Use a pair of tweezers to remove the electrical connector for the hinge. Pull gently while wiggling the connector back and forth.
    • Remove the adhesive tape holding the wire down.
  8. Acer One 10 S1003-114M Screen Hinge Replacement: adım 8, 2 resimden 1. Acer One 10 S1003-114M Screen Hinge Replacement: adım 8, 2 resimden 2.
    • To free the hinge, remove the 4 mount screws with a Phillips #0 screwdriver.
  9. Acer One 10 S1003-114M Screen Hinge Replacement: adım 9, 2 resimden 1. Acer One 10 S1003-114M Screen Hinge Replacement: adım 9, 2 resimden 2.
    • Remove the disconnected hinge from the keyboard.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Justin Bawinkel
327 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S2-G6, Harley Spring 2019 IUPUI, Team S2-G6, Harley Spring 2019 üyesi
IUPUI-HARLEY-S19S2G6
4 Üyeler
2 adet Kılavuz yazıldı
5 Yorum
Where can I buy the hinges of acer one 10 D16H1?
ladysam020889 - Yanıt
Do you know where I can find hinges of acer one s1003?
Al Monslisa - Yanıt
The hinge is so stiff it broke off the keyboard tabs. I need to loosen the hinge and replace the keyboard base, or hopefully just the positioning tabs (if they can be reglued).
PGI Cruiser - Yanıt
Tutoriel bien expliqué, merci pour tout, vous m’avez bien aidé à changer la charnière moi-même.
Francis Meylemans - Yanıt
Where can i buy new hinge for acer one s1003 , plss suggest me
Arvind - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 30
Her zaman: 6,216
