Ana içeriğe geç
Acer One 10 S1003-114M Track Pad Replacement
Neye ihtiyacın var
  1. Acer One 10 S1003-114M Track Pad Replacement, Track Pad: adım 1, 1 resimden 1.
    • Open the screen.
  2. Acer One 10 S1003-114M Track Pad Replacement: adım 2, 1 resimden 1.
    • Remove the screen portion from the keyboard.
  3. Acer One 10 S1003-114M Track Pad Replacement: adım 3, 2 resimden 1. Acer One 10 S1003-114M Track Pad Replacement: adım 3, 2 resimden 2.
    • Turn over the keyboard and use the plastic pry tool to remove the two adhesive backed rubber pads furthest from the hinge.
  4. Acer One 10 S1003-114M Track Pad Replacement: adım 4, 3 resimden 1. Acer One 10 S1003-114M Track Pad Replacement: adım 4, 3 resimden 2. Acer One 10 S1003-114M Track Pad Replacement: adım 4, 3 resimden 3.
    • Remove ten total screws from the back cover with a Phillips #1 screwdriver.
    • 8 screws 4.25mm in length with 4.00mm diameter heads.
    • 2 screws 6.00mm in length with 4.00mm diameter heads.
  5. Acer One 10 S1003-114M Track Pad Replacement: adım 5, 1 resimden 1.
    • Use the plastic opening tool to separate the front and back halves of the keyboard.
  6. Acer One 10 S1003-114M Track Pad Replacement: adım 6, 1 resimden 1.
    • Lift away the loosened back cover.
  7. Acer One 10 S1003-114M Track Pad Replacement: adım 7, 1 resimden 1.
    • Use an opening tool to remove/peel off the adhesive tape from the trackpad electrical connector
  8. Acer One 10 S1003-114M Track Pad Replacement: adım 8, 2 resimden 1. Acer One 10 S1003-114M Track Pad Replacement: adım 8, 2 resimden 2.
    • Use an opening tool to flip/pop the switch holding down the electric connector to the keyboard.
  9. Acer One 10 S1003-114M Track Pad Replacement: adım 9, 2 resimden 1. Acer One 10 S1003-114M Track Pad Replacement: adım 9, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Use the fine tip tweezers to remove the electrical connector for the trackpad. Pull gently.
  10. Acer One 10 S1003-114M Track Pad Replacement: adım 10, 3 resimden 1. Acer One 10 S1003-114M Track Pad Replacement: adım 10, 3 resimden 2. Acer One 10 S1003-114M Track Pad Replacement: adım 10, 3 resimden 3.
    • To free the retainer, remove the 2 mount screws, 3.50mm length and 4.90mm diameter heads, with a Phillips #0 screwdriver.
  11. Acer One 10 S1003-114M Track Pad Replacement: adım 11, 1 resimden 1.
    • To free the trackpad, remove the 2 mount screws, 3.50mm length and 4.90mm diameter heads, with a Phillips #0 screwdriver.
  12. Acer One 10 S1003-114M Track Pad Replacement: adım 12, 1 resimden 1.
    • Use a pair of fine tip tweezers to remove the adhesive metallic strap holding the trackpad to the keyboard.
  13. Acer One 10 S1003-114M Track Pad Replacement: adım 13, 1 resimden 1.
    • Gently remove the trackpad from the keyboard.
Sonuç
Karan Karthik
217 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S2-G6, Harley Spring 2019 IUPUI, Team S2-G6, Harley Spring 2019 üyesi
IUPUI-HARLEY-S19S2G6
4 Üyeler
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 4
Son 30 gün: 19
Her zaman: 746
