Ana içeriğe geç
Acer One 10 S1003-19GY Rear/Front Camera Replacement
Neye ihtiyacın var
  1. Acer One 10 S1003-19GY Rear/Front Camera Replacement, Back Panel: adım 1, 2 resimden 1. Acer One 10 S1003-19GY Rear/Front Camera Replacement, Back Panel: adım 1, 2 resimden 2.
    • Power off the device and make sure it is disconnected from any external devices.
    • Use a plastic opening tool to create a gap between the front and back casing of the device.
    • Slowly maneuver the plastic tool around the entire perimeter of the tablet to separate the front and back.
  2. Acer One 10 S1003-19GY Rear/Front Camera Replacement: adım 2, 1 resimden 1.
    • Set the device screen side down and remove the back casing.
  3. Acer One 10 S1003-19GY Rear/Front Camera Replacement, Front/Rear Camera: adım 3, 1 resimden 1.
    • Locate the Rear Camera in the upper right hand corner of the motherboard.
  4. Acer One 10 S1003-19GY Rear/Front Camera Replacement: adım 4, 3 resimden 1. Acer One 10 S1003-19GY Rear/Front Camera Replacement: adım 4, 3 resimden 2. Acer One 10 S1003-19GY Rear/Front Camera Replacement: adım 4, 3 resimden 3.
    • Using a relatively thin flat head screwdriver, pry the camera connection from the motherboard.
    • The connection should remove easily as it just snaps to the motherboard.
  5. Acer One 10 S1003-19GY Rear/Front Camera Replacement: adım 5, 1 resimden 1.
    • Remove the five screws on the outer edge of the motherboard using a Phillips #0 screwdriver.
  6. Acer One 10 S1003-19GY Rear/Front Camera Replacement: adım 6, 2 resimden 1. Acer One 10 S1003-19GY Rear/Front Camera Replacement: adım 6, 2 resimden 2.
    • Open the black flap on the connection and gently pull the ribbon from it.
    • Slightly raise the motherboard from the upper side to remove the camera as shown.
Sonuç
Trey Wintzinger
605 İtibar
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 7
Her zaman: 354
