Giriş
Replacement fix for broken WiFi connection if all other troubleshooting options have failed.
Parçalar
Hiçbir parçaya gerek yok.
  1. Power off the device and make sure it is disconnected from any external devices.
    • Power off the device and make sure it is disconnected from any external devices.
    • Use a plastic opening tool to create a gap between the front and back casing of the device.
    • Slowly maneuver the plastic tool around the entire perimeter of the tablet to separate the front and back.
  2. Set the device screen side down and remove the back casing.
    • Set the device screen side down and remove the back casing.
    • Disconnect the black ribbon connection attached to the motherboard.
    • Remove the chip fully by pulling the plastic tab on the left out.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Trey Wintzinger
587 İtibar
5 adet Kılavuz yazıldı
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 Gün: 2
Son 30 Gün: 30
Her zaman: 39
