Ana içeriğe geç
Acer Predator 17 G9-791 Battery Replacement
Neye ihtiyacın var
  1. Acer Predator 17 G9-791 Battery Replacement, Service Panel: adım 1, 1 resimden 1.
    • The service panel can be located on the bottom of the device. It is shown here as the panel located in the middle of the device, going from the upper vents to the bottom of the device.
  2. Acer Predator 17 G9-791 Battery Replacement: adım 2, 2 resimden 1. Acer Predator 17 G9-791 Battery Replacement: adım 2, 2 resimden 2.
    • Loosen the two Phillips #0 screws.
    • Pull up slightly on the top of the panel to help fully separate the screws from the rest of the device.
  3. Acer Predator 17 G9-791 Battery Replacement: adım 3, 1 resimden 1.
    • Continue pulling up on the panel to separate it from the laptop and remove it.
  4. Acer Predator 17 G9-791 Battery Replacement, Bottom Case: adım 4, 3 resimden 1. Acer Predator 17 G9-791 Battery Replacement, Bottom Case: adım 4, 3 resimden 2. Acer Predator 17 G9-791 Battery Replacement, Bottom Case: adım 4, 3 resimden 3.
    • Remove the nine 4.5 mm Phillips #0 screws from the panel.
    • Remove four 14 mm Phillips #0 screws.
    • Remove six 7 mm Phillips #0 screws.
  5. Acer Predator 17 G9-791 Battery Replacement: adım 5, 1 resimden 1.
    • Slide the "unlock" slider up located to the right of the service panel and pull the disc tray out.
  6. Acer Predator 17 G9-791 Battery Replacement: adım 6, 1 resimden 1.
    • Remove the two 4.5 mm Phillips #0 screws located underneath the removed optical drive.
  7. Acer Predator 17 G9-791 Battery Replacement: adım 7, 2 resimden 1. Acer Predator 17 G9-791 Battery Replacement: adım 7, 2 resimden 2.
    • Pry up on the edges of the bottom cover and lift the bottom case off of the device.
  8. Acer Predator 17 G9-791 Battery Replacement, Battery: adım 8, 1 resimden 1.
    • Remove the six 4 mm Phillips #0 screws from the battery.
  9. Acer Predator 17 G9-791 Battery Replacement: adım 9, 2 resimden 1. Acer Predator 17 G9-791 Battery Replacement: adım 9, 2 resimden 2.
    • Disconnect the battery connector from the motherboard.
  10. Acer Predator 17 G9-791 Battery Replacement: adım 10, 1 resimden 1.
    • Gently lift the battery and remove it from the device.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Matthew Shane
376 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 5-1, Sinclaire Fall 2022 UMass Dartmouth, Team 5-1, Sinclaire Fall 2022 üyesi
UMASSD-SINCLAIRE-F22S5G1
5 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 12
Son 30 gün: 52
Her zaman: 1,133
