Ana içeriğe geç
Acer Predator 17 G9-791 Service Panel Replacement
Neye ihtiyacın var
  1. Acer Predator 17 G9-791 Service Panel Replacement, Service Panel: adım 1, 1 resimden 1.
    • The service panel can be located on the bottom of the device. It is shown here as the panel located in the middle of the device, going from the upper vents to the bottom of the device.
  2. Acer Predator 17 G9-791 Service Panel Replacement: adım 2, 2 resimden 1. Acer Predator 17 G9-791 Service Panel Replacement: adım 2, 2 resimden 2.
    • Loosen the two Phillips #0 screws.
    • Pull up slightly on the top of the panel to help fully separate the screws from the rest of the device.
  3. Acer Predator 17 G9-791 Service Panel Replacement: adım 3, 1 resimden 1.
    • Continue pulling up on the panel to separate it from the laptop and remove it.
Sonuç
Matthew Shane
376 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 5-1, Sinclaire Fall 2022 UMass Dartmouth, Team 5-1, Sinclaire Fall 2022 üyesi
UMASSD-SINCLAIRE-F22S5G1
5 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 4
Her zaman: 125
