Ana içeriğe geç
Acer Predator Helios 300 Battery Replacement
Neye ihtiyacın var
  1. Acer Predator Helios 300 Battery Replacement, Battery: adım 1, 3 resimden 1. Acer Predator Helios 300 Battery Replacement, Battery: adım 1, 3 resimden 2. Acer Predator Helios 300 Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Before you start make sure the laptop is grounded.
    • Make sure the laptop is powered off.
    • If the laptop is not turned off, there is a risk of electric shock when replacing the battery.
    • Close the cover of the laptop, then turn the laptop upside down so the back is facing up.
  2. Acer Predator Helios 300 Battery Replacement: adım 2, 3 resimden 1. Acer Predator Helios 300 Battery Replacement: adım 2, 3 resimden 2. Acer Predator Helios 300 Battery Replacement: adım 2, 3 resimden 3.
    • Remove all the screws from the back panel with a Phillips #0 screwdriver.
    • Remove the hard drive screw using a Phillips #0 screwdriver.
    • Use the panel tool to pop the storage hard disk open.
  3. Acer Predator Helios 300 Battery Replacement: adım 3, 3 resimden 1. Acer Predator Helios 300 Battery Replacement: adım 3, 3 resimden 2. Acer Predator Helios 300 Battery Replacement: adım 3, 3 resimden 3.
    • Remove the four screws mounted near the storage hard disk using a Phillips #0 screwdriver.
    • Disconnect the cable connected to the storage hard disk.
  4. Acer Predator Helios 300 Battery Replacement: adım 4, 3 resimden 1. Acer Predator Helios 300 Battery Replacement: adım 4, 3 resimden 2. Acer Predator Helios 300 Battery Replacement: adım 4, 3 resimden 3.
    • Use the panel tool to remove the back cover.
    • Slowly open the clips attached to the back cover, and store the cover safely.
  5. Acer Predator Helios 300 Battery Replacement: adım 5, 3 resimden 1. Acer Predator Helios 300 Battery Replacement: adım 5, 3 resimden 2. Acer Predator Helios 300 Battery Replacement: adım 5, 3 resimden 3.
    • Remove the tape holding the battery wires in.
    • Remove the two screws mounted next to the battery using a Phillips #0 screwdriver.
    • Disconnect the battery cable from the motherboard slowly.
    • Remove the old battery.
  6. Acer Predator Helios 300 Battery Replacement: adım 6, 3 resimden 1. Acer Predator Helios 300 Battery Replacement: adım 6, 3 resimden 2. Acer Predator Helios 300 Battery Replacement: adım 6, 3 resimden 3.
    • The battery is a Household Hazardous Waste, so be sure to follow your city's laws and dispose of them properly.
    • Connect the new battery connector to the motherboard and screw it back with the screwdriver.
  7. Acer Predator Helios 300 Battery Replacement: adım 7, 2 resimden 1. Acer Predator Helios 300 Battery Replacement: adım 7, 2 resimden 2.
    • Align the back cover with the laptop properly and click it with all the clips.
  8. Acer Predator Helios 300 Battery Replacement: adım 8, 3 resimden 1. Acer Predator Helios 300 Battery Replacement: adım 8, 3 resimden 2. Acer Predator Helios 300 Battery Replacement: adım 8, 3 resimden 3.
    • Insert the storage disk back in.
    • Connect it with the cable first and then fit it inside the missing space.
    • Fasten the remaining screws using a screwdriver.
Bitiş Çizgisi
3 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 49
Son 30 gün: 182
Her zaman: 4,933
