Ana içeriğe geç
Giriş
Using the Acer S200HL LCD Monitor motherboard replacement and removal guide, this process will become easier using these simple iFixit steps.
  1. Acer S200HL LCD Monitor Motherboard Replacement, Removing the Stand: step 1, image 1 of 2 Acer S200HL LCD Monitor Motherboard Replacement, Removing the Stand: step 1, image 2 of 2
    • Place the monitor screen face down.
    • Firmly hold the base of the stand with one hand and the bottom of the monitor with the other hand.
    • Pull the stand away from the monitor.
  2. Acer S200HL LCD Monitor Motherboard Replacement, Removing the Back Panel: step 2, image 1 of 3 Acer S200HL LCD Monitor Motherboard Replacement, Removing the Back Panel: step 2, image 2 of 3 Acer S200HL LCD Monitor Motherboard Replacement, Removing the Back Panel: step 2, image 3 of 3
    • Use the plastic opening tool to pry the back panel from the front panel.
    • Start at one point of the crease and pry along the edge of the entire monitor for the best results.
  3. Acer S200HL LCD Monitor Motherboard Replacement: step 3, image 1 of 1
    • Gently lift back panel away from the monitor.
  4. Acer S200HL LCD Monitor Motherboard Replacement, Removing Interior Motherboard Casing: step 4, image 1 of 2 Acer S200HL LCD Monitor Motherboard Replacement, Removing Interior Motherboard Casing: step 4, image 2 of 2
    • Be sure to keep track of where you place your screws. A magnetic mat is great for keeping your screws in one spot.
    • Unscrew the four 7.5 mm Phillips #2 screws connecting the motherboard to the metal casing.
  5. Acer S200HL LCD Monitor Motherboard Replacement: step 5, image 1 of 2 Acer S200HL LCD Monitor Motherboard Replacement: step 5, image 2 of 2
    • Remove the four 10 mm hex screws.
  6. Acer S200HL LCD Monitor Motherboard Replacement: step 6, image 1 of 1
    • Gently lift the motherboard casing from the monitor.
  7. Acer S200HL LCD Monitor Motherboard Replacement, Removing the Connections to the Motherboard: step 7, image 1 of 1
    • The following steps circled in yellow are the locations for detaching the three connectors shown in the picture.
    Good morning sir my monitor mother board damaged sir.so please I want a mother board sir,how is getting and how much cost sir please tell me sir
    Model :S200HL
    LCD Monitor
    AAKULA NAGARAJU - Yanıt
  8. Acer S200HL LCD Monitor Motherboard Replacement, Removing the No Fuss Ribbon Cable Connector: step 8, image 1 of 1
    • Lift the black seal to release the small ribbon connector (the No Fuss Ribbon Cable connector) from the motherboard.
    • The connector will be released from the motherboard immediately.
  9. Acer S200HL LCD Monitor Motherboard Replacement, Removing the ZIF Connectors: step 9, image 1 of 1
    • Lift the black seal to release the large ribbon connector (the ZIF connector).
  10. Acer S200HL LCD Monitor Motherboard Replacement, Removing the Bundled Cable Connector: step 10, image 1 of 1
    • Pull the bundled cable connector gently away from motherboard.
  11. Acer S200HL LCD Monitor Motherboard Replacement, Removing the Motherboard: step 11, image 1 of 1
    • Gently lift the motherboard to remove it from the monitor.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Jeffrey Kong
760 İtibar
5 adet Kılavuz yazıldı
Takım
Cal Poly, Team 12-3, Forte Fall 2014 Cal Poly, Team 12-3, Forte Fall 2014 üyesi
CPSU-FORTE-F14S12G3
5 Üyeler
2 Yorum
como saber si es la board o las lamparas q trae la pantalla?
y cual es la forma de reparar las lamparas
Doc acvdo - Yanıt
What is the specific name of that dc-in power jack?I’ m trying to replace that thing with a new one,the current one is already faulty.Can u recommend me where to find that part?Thanks!
Oreo - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 49
Her zaman: 5,736
