Ana içeriğe geç
Acer Spin 3 SP315-51-79NT Screen Assembly Replacement
Neye ihtiyacın var
  1. Acer Spin 3 SP315-51-79NT Screen Assembly Replacement, Back Panel: adım 1, 2 resimden 1. Acer Spin 3 SP315-51-79NT Screen Assembly Replacement, Back Panel: adım 1, 2 resimden 2.
    • Using the Phillips #1 screwdriver, remove twelve (12) screws from the back panel.
  2. Acer Spin 3 SP315-51-79NT Screen Assembly Replacement: adım 2, 2 resimden 1. Acer Spin 3 SP315-51-79NT Screen Assembly Replacement: adım 2, 2 resimden 2.
    • Gently pry the back plate off with your fingers.
  3. Acer Spin 3 SP315-51-79NT Screen Assembly Replacement, Screen Assembly: adım 3, 2 resimden 1. Acer Spin 3 SP315-51-79NT Screen Assembly Replacement, Screen Assembly: adım 3, 2 resimden 2.
    • Using the Phillips #1 screwdriver, remove a total of four screws from the hinges (two on each hinge).
  4. Acer Spin 3 SP315-51-79NT Screen Assembly Replacement: adım 4, 2 resimden 1. Acer Spin 3 SP315-51-79NT Screen Assembly Replacement: adım 4, 2 resimden 2.
    • Remove wires connecting to motherboard.
    • You can then simply pull the two halves of the computer away from each other.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Michael Duross
472 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-1, Sinclaire Fall 2021 UMass Dartmouth, Team 2-1, Sinclaire Fall 2021 üyesi
UMASSD-SINCLAIRE-F21S2G1
3 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 23
Her zaman: 385
