Ana içeriğe geç
Acer Spin 5 N17W2 Cooling Fan Replacement
Neye ihtiyacın var
  1. Acer Spin 5 N17W2 Cooling Fan Replacement, Cooling Fan: adım 1, 2 resimden 1. Acer Spin 5 N17W2 Cooling Fan Replacement, Cooling Fan: adım 1, 2 resimden 2.
    • Use the Phillips #1 screwdriver to remove six 6 mm screws.
    • Use the same screwdriver to remove six 5mm screws.
  2. Acer Spin 5 N17W2 Cooling Fan Replacement: adım 2, 1 resimden 1.
    • Use an opening tool to pry the back cover open.
  3. Acer Spin 5 N17W2 Cooling Fan Replacement: adım 3, 1 resimden 1.
    • Remove two 5 mm screws by using the Phillips #1 screwdriver.
  4. Acer Spin 5 N17W2 Cooling Fan Replacement: adım 4, 2 resimden 1. Acer Spin 5 N17W2 Cooling Fan Replacement: adım 4, 2 resimden 2.
    • Use two opening tools to disconnect the cooling fan from the motherboard.
    • Remove the fan from the device.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 24
Her zaman: 873
