Ana içeriğe geç
Acer Spin 5 N17W2 Hard Drive Replacement
Neye ihtiyacın var
  1. Acer Spin 5 N17W2 Hard Drive Replacement, Battery: adım 1, 2 resimden 1. Acer Spin 5 N17W2 Hard Drive Replacement, Battery: adım 1, 2 resimden 2.
    • Be sure to power off and unplug your device before you begin your repair.
    • Remove the twelve screws on the back cover using the Phillips #1 screwdriver.
  2. Acer Spin 5 N17W2 Hard Drive Replacement: adım 2, 1 resimden 1.
    • Use an opening tool to pry the back cover open.
  3. Acer Spin 5 N17W2 Hard Drive Replacement: adım 3, 1 resimden 1.
    • Remove two 4 mm screws at the two corners of the battery using the Phillips #1 screwdriver.
  4. Acer Spin 5 N17W2 Hard Drive Replacement: adım 4, 1 resimden 1.
    • Carefully remove the three tapes on the battery.
  5. Acer Spin 5 N17W2 Hard Drive Replacement: adım 5, 1 resimden 1.
    • Carefully slide the battery connector out of its motherboard socket.
  6. Acer Spin 5 N17W2 Hard Drive Replacement: adım 6, 1 resimden 1.
    • Remove the battery from the device.
  7. Acer Spin 5 N17W2 Hard Drive Replacement, Hard Drive: adım 7, 1 resimden 1.
    • Disconnect the hard drive and remove it from the device.
    • At the time of guide creation, the hard drive was not included in the device.
Sonuç
2 Yorum
You highlighted some random spot for the hard drive but you should have highlighted the empty m.2 slot which doesn’t even require you to remove the battery.
Peter Iliopoulos - Yanıt
Agreed. This guide is pointless. Just a random, inaccurate guess. Why even bother putting this together if you don't know what you're talking about.
Stephen Feger - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 21
Her zaman: 2,693
