Ana içeriğe geç
Acer Spin 5 N17W2 Motherboard Replacement
Neye ihtiyacın var
  1. Acer Spin 5 N17W2 Motherboard Replacement, Cooling Fan: adım 1, 2 resimden 1. Acer Spin 5 N17W2 Motherboard Replacement, Cooling Fan: adım 1, 2 resimden 2.
    • Use the Phillips #1 screwdriver to remove six 6 mm screws.
    • Use the same screwdriver to remove six 5mm screws.
  2. Acer Spin 5 N17W2 Motherboard Replacement: adım 2, 1 resimden 1.
    • Use an opening tool to pry the back cover open.
  3. Acer Spin 5 N17W2 Motherboard Replacement: adım 3, 1 resimden 1.
    • Remove two 5 mm screws by using the Phillips #1 screwdriver.
  4. Acer Spin 5 N17W2 Motherboard Replacement: adım 4, 2 resimden 1. Acer Spin 5 N17W2 Motherboard Replacement: adım 4, 2 resimden 2.
    • Use two opening tools to disconnect the cooling fan from the motherboard.
    • Remove the fan from the device.
  5. Acer Spin 5 N17W2 Motherboard Replacement, Motherboard: adım 5, 1 resimden 1.
    • Remove four 5 mm screws using the Phillips #1 screwdriver.
  6. Acer Spin 5 N17W2 Motherboard Replacement: adım 6, 1 resimden 1.
    • Take off the black heat sink (be careful of the grey thermal grease).
  7. Acer Spin 5 N17W2 Motherboard Replacement: adım 7, 3 resimden 1. Acer Spin 5 N17W2 Motherboard Replacement: adım 7, 3 resimden 2. Acer Spin 5 N17W2 Motherboard Replacement: adım 7, 3 resimden 3.
    • Remove all peripherals connecting to the motherboard.
    • Remove the second chip.
    • Remove the wireless LAN chip.
  8. Acer Spin 5 N17W2 Motherboard Replacement: adım 8, 1 resimden 1.
    • Disconnect the three connection wires.
  9. Acer Spin 5 N17W2 Motherboard Replacement: adım 9, 2 resimden 1. Acer Spin 5 N17W2 Motherboard Replacement: adım 9, 2 resimden 2.
    • Take off the connecting port with black tape.
    • Take off the last port with purple tape.
  10. Acer Spin 5 N17W2 Motherboard Replacement: adım 10, 1 resimden 1.
    • Remove the motherboard from the device.
Sonuç
2 Yorum
I need the motherboard where I can buy it..
john fredy mendoza torres - Yanıt
I need the motherboard where I can buy it please...
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 16
Her zaman: 1,443
