Ana içeriğe geç
Acer Spin 5 N17W2 Screen Assembly Replacement
Neye ihtiyacın var
  1. Acer Spin 5 N17W2 Screen Assembly Replacement, Screen Assembly: adım 1, 2 resimden 1. Acer Spin 5 N17W2 Screen Assembly Replacement, Screen Assembly: adım 1, 2 resimden 2.
    • Use the Phillips #1 screwdriver to remove the six 6mm screws.
    • Use Phillips #1 screwdriver to remove six 5mm screws.
  2. Acer Spin 5 N17W2 Screen Assembly Replacement: adım 2, 1 resimden 1.
    • Use an opening tool to pry the back cover open.
  3. Acer Spin 5 N17W2 Screen Assembly Replacement: adım 3, 1 resimden 1.
    • Use the Phillips #1 screwdriver to remove the three 5mm screws.
    • Use the Phillips #1 screwdriver to remove the three 5mm screws on another side of hinge.
  4. Acer Spin 5 N17W2 Screen Assembly Replacement: adım 4, 1 resimden 1.
    • Disconnect chips from the two end side of hinge.
  5. Acer Spin 5 N17W2 Screen Assembly Replacement: adım 5, 1 resimden 1.
    • Use the plastic opening tool to pry the hinge up.
  6. Acer Spin 5 N17W2 Screen Assembly Replacement: adım 6, 1 resimden 1.
    • Remove the wireless LAN chip from the motherboard.
  7. Acer Spin 5 N17W2 Screen Assembly Replacement: adım 7, 1 resimden 1.
    • Detach the sensors on each side of the hinge from the motherboard.
  8. Acer Spin 5 N17W2 Screen Assembly Replacement: adım 8, 1 resimden 1.
    • Detach the screen assembly from the device.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 34
Her zaman: 2,527
