Giriş
The trackpad is the component that tracks all user finger movement on a laptop. If your laptop is not properly tracking the movements of your cursor, the trackpad may need to be replaced. Follow these instructions to remove and replace the trackpad in your device.
Neye ihtiyacın var
Remove the twelve screws on the back cover using the Phillips #1 screwdriver.
Using the blue spudger, pry the two black clips from the two ribbon cables on the bottom of the mouse pad.
