Ana içeriğe geç
Acer Spin 5 SP513-51-57TP Cooling Fan Replacement
Neye ihtiyacın var
  1. Acer Spin 5 SP513-51-57TP Cooling Fan Replacement, Battery: adım 1, 1 resimden 1.
    • Flip your laptop over so that the model sticker is facing upward towards the ceiling.
    • Make sure your computer is turned off before starting to avoid getting shocked.
  2. Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: adım 2, 2 resimden 1. Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: adım 2, 2 resimden 2.
    • Use a Phillips #1 screwdriver to remove the thirteen 6.5mm screws that secure the back cover.
  3. Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: adım 3, 3 resimden 1. Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: adım 3, 3 resimden 2. Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: adım 3, 3 resimden 3.
    • Use a plastic opening tool to gently separate the back cover from the laptop. A snapping sound will be heard as a signal that the clips are being disengaged.
    • Do not use any metal tools to pry open the device.
    • It is recommended that you start from one corner and run the tool along the edges of your laptop from corner to corner for a safe removal.
  4. Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: adım 4, 3 resimden 1. Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: adım 4, 3 resimden 2. Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: adım 4, 3 resimden 3.
    • Use a Phillips #1 screwdriver to remove two 4 mm screws that secure the battery.
  5. Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: adım 5, 3 resimden 1. Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: adım 5, 3 resimden 2. Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: adım 5, 3 resimden 3.
    • Use your hand to carefully pull out the wiring harness from its port that is located between the battery and the motherboard.
    • Remove the battery from the case.
  6. Acer Spin 5 SP513-51-57TP Cooling Fan Replacement, Cooling Fan: adım 6, 3 resimden 1. Acer Spin 5 SP513-51-57TP Cooling Fan Replacement, Cooling Fan: adım 6, 3 resimden 2. Acer Spin 5 SP513-51-57TP Cooling Fan Replacement, Cooling Fan: adım 6, 3 resimden 3.
    • Use Phillips #1 screwdriver to remove the two 4mm screws that are securing the fan.
  7. Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: adım 7, 2 resimden 1. Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: adım 7, 2 resimden 2.
    • Using Phillips #1 screwdriver remove three 5 mm screws to remove the heatsink.
    • When removing the cooling fan, the heatsink component will stay connected.
  8. Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: adım 8, 3 resimden 1. Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: adım 8, 3 resimden 2. Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: adım 8, 3 resimden 3.
    • Using your hand, pull out wiring harness to disconnect the fan from the motherboard.
    • Lift the fan out of the case to remove it.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Anthony Vansell
872 İtibar
5 adet Kılavuz yazıldı
Ekip
Hufflepuff Hufflepuff üyesi
Repair Café
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 7
Her zaman: 1,257
