Giriş
The motherboard holds together many of the crucial components of your computer. If your motherboard is failing your computer will display an error code with a series of audible beeps. It will also display the “Blue Screen of Death” representing it has failed.
Motherboard: Definition. A motherboard is one of the most essential parts of a computer system. It holds together many of the crucial components of a computer, including the central processing unit (CPU), memory and connectors for input and output devices.
Common symptoms of motherboard issues are similar to CPU problems: The system does not display anything; an error code appears; one or more beeps occur; the system locks; the system reboots; a Windows BSOD (blue screen of death) appears; or one or more of the ports, expansion slots, or memory modules fails.
Neye ihtiyacın var
Flip your laptop over so that the model sticker is facing upward towards the ceiling.
Grasp the CMOS battery with the tweezers and remove it from the motherboard.
Using a Phillips #1 screwdriver, remove the one 4mm screw that secures the Solid State Drive.
Use Phillips #1 screwdriver to remove the two 4mm screws that are securing the fan.
Use the tweezers to disconnect the wiring harness in the bottom right corner of your laptop.
Bir Yorum
I was wondering if the CPU is soldered to the motherboard? Is it possible to remove the CPU and replace it with an upgraded CPU?
