Ana içeriğe geç
Acer Spin 5 SP513-51-57TP Solid State Drive Replacement
Neye ihtiyacın var
  1. Acer Spin 5 SP513-51-57TP Solid State Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Flip your laptop over so that the model sticker is facing upward towards the ceiling.
    • Make sure your computer is turned off before starting to avoid getting shocked.
  2. Acer Spin 5 SP513-51-57TP Solid State Drive Replacement: adım 2, 2 resimden 1. Acer Spin 5 SP513-51-57TP Solid State Drive Replacement: adım 2, 2 resimden 2.
    • Use a Phillips #1 screwdriver to remove the thirteen 6.5mm screws that secure the back cover.
  3. Acer Spin 5 SP513-51-57TP Solid State Drive Replacement: adım 3, 3 resimden 1. Acer Spin 5 SP513-51-57TP Solid State Drive Replacement: adım 3, 3 resimden 2. Acer Spin 5 SP513-51-57TP Solid State Drive Replacement: adım 3, 3 resimden 3.
    • Use a plastic opening tool to gently separate the back cover from the laptop. A snapping sound will be heard as a signal that the clips are being disengaged.
    • Do not use any metal tools to pry open the device.
    • It is recommended that you start from one corner and run the tool along the edges of your laptop from corner to corner for a safe removal.
  4. Acer Spin 5 SP513-51-57TP Solid State Drive Replacement: adım 4, 3 resimden 1. Acer Spin 5 SP513-51-57TP Solid State Drive Replacement: adım 4, 3 resimden 2. Acer Spin 5 SP513-51-57TP Solid State Drive Replacement: adım 4, 3 resimden 3.
    • Use a Phillips #1 screwdriver to remove two 4 mm screws that secure the battery.
  5. Acer Spin 5 SP513-51-57TP Solid State Drive Replacement: adım 5, 3 resimden 1. Acer Spin 5 SP513-51-57TP Solid State Drive Replacement: adım 5, 3 resimden 2. Acer Spin 5 SP513-51-57TP Solid State Drive Replacement: adım 5, 3 resimden 3.
    • Use your hand to carefully pull out the wiring harness from its port that is located between the battery and the motherboard.
    • Remove the battery from the case.
  6. Acer Spin 5 SP513-51-57TP Solid State Drive Replacement, Solid State Drive: adım 6, 3 resimden 1. Acer Spin 5 SP513-51-57TP Solid State Drive Replacement, Solid State Drive: adım 6, 3 resimden 2. Acer Spin 5 SP513-51-57TP Solid State Drive Replacement, Solid State Drive: adım 6, 3 resimden 3.
    • Using a Phillips #1 screwdriver, remove the one 4mm screw that secures the Solid State Drive.
  7. Acer Spin 5 SP513-51-57TP Solid State Drive Replacement: adım 7, 3 resimden 1. Acer Spin 5 SP513-51-57TP Solid State Drive Replacement: adım 7, 3 resimden 2. Acer Spin 5 SP513-51-57TP Solid State Drive Replacement: adım 7, 3 resimden 3.
    • Use your hand to pull out the Solid State Drive from the motherboard.
    • You will be pulling the solid state drive out to the left, as it will be connected to the port on the motherboard on its right side. This is opposite the direction that the pictures depict it.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Anthony Vansell
872 İtibar
5 adet Kılavuz yazıldı
Ekip
Hufflepuff Hufflepuff üyesi
Local Repair Groups
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 13
Son 30 gün: 51
Her zaman: 1,813
