Ana içeriğe geç
Acer Spin 5 SP515-51GN-807G Fan Replacement
Neye ihtiyacın var
  1. Acer Spin 5 SP515-51GN-807G Fan Replacement, Back Cover: adım 1, 1 resimden 1.
    • Remove the eleven 6.5 mm screws that secure the back case using a Phillips #1 screwdriver.
  2. Acer Spin 5 SP515-51GN-807G Fan Replacement: adım 2, 3 resimden 1. Acer Spin 5 SP515-51GN-807G Fan Replacement: adım 2, 3 resimden 2. Acer Spin 5 SP515-51GN-807G Fan Replacement: adım 2, 3 resimden 3.
    • Use a plastic opening tool to gently pry open the back cover.
  3. Acer Spin 5 SP515-51GN-807G Fan Replacement: adım 3, 1 resimden 1.
    • Gently remove the back cover from the device.
  4. Acer Spin 5 SP515-51GN-807G Fan Replacement, Battery: adım 4, 3 resimden 1. Acer Spin 5 SP515-51GN-807G Fan Replacement, Battery: adım 4, 3 resimden 2. Acer Spin 5 SP515-51GN-807G Fan Replacement, Battery: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Using tweezers, remove the piece of black tape over the battery cable connector.
  5. Acer Spin 5 SP515-51GN-807G Fan Replacement: adım 5, 3 resimden 1. Acer Spin 5 SP515-51GN-807G Fan Replacement: adım 5, 3 resimden 2. Acer Spin 5 SP515-51GN-807G Fan Replacement: adım 5, 3 resimden 3.
    • Remove the piece of black tape that covers the battery.
  6. Acer Spin 5 SP515-51GN-807G Fan Replacement: adım 6, 2 resimden 1. Acer Spin 5 SP515-51GN-807G Fan Replacement: adım 6, 2 resimden 2.
    • Grip the battery cable on both sides with your fingertips and gently pull it away from the port.
    • If needed, use the plastic opening tool to remove the cord from its port.
  7. Acer Spin 5 SP515-51GN-807G Fan Replacement: adım 7, 3 resimden 1. Acer Spin 5 SP515-51GN-807G Fan Replacement: adım 7, 3 resimden 2. Acer Spin 5 SP515-51GN-807G Fan Replacement: adım 7, 3 resimden 3.
    • Remove the two 3.5 mm screws that secure the battery using a Phillips #00 screwdriver (PH00 bit).
  8. Acer Spin 5 SP515-51GN-807G Fan Replacement: adım 8, 2 resimden 1. Acer Spin 5 SP515-51GN-807G Fan Replacement: adım 8, 2 resimden 2.
    • Carefully place your fingers under the plastic lip where the screws were removed.
    • Lift upwards to remove the battery.
    • Do not bend or puncture the lithium ion battery as it poses a fire hazard.
  9. Acer Spin 5 SP515-51GN-807G Fan Replacement, Fan: adım 9, 3 resimden 1. Acer Spin 5 SP515-51GN-807G Fan Replacement, Fan: adım 9, 3 resimden 2. Acer Spin 5 SP515-51GN-807G Fan Replacement, Fan: adım 9, 3 resimden 3.
    Satın Al
    • Remove the piece of tape covering the fan screw using a pair of tweezers.
    • This can also be done using your fingernail.
  10. Acer Spin 5 SP515-51GN-807G Fan Replacement: adım 10, 3 resimden 1. Acer Spin 5 SP515-51GN-807G Fan Replacement: adım 10, 3 resimden 2. Acer Spin 5 SP515-51GN-807G Fan Replacement: adım 10, 3 resimden 3.
    • Grip the cord that connects the fan to the motherboard and gently pull out to disconnect the cable from the connector.
  11. Acer Spin 5 SP515-51GN-807G Fan Replacement: adım 11, 2 resimden 1. Acer Spin 5 SP515-51GN-807G Fan Replacement: adım 11, 2 resimden 2.
    • Remove the 3.5 mm screw connecting the fan to the computer using a Phillips #00 screwdriver (PH00 bit).
  12. Acer Spin 5 SP515-51GN-807G Fan Replacement: adım 12, 2 resimden 1. Acer Spin 5 SP515-51GN-807G Fan Replacement: adım 12, 2 resimden 2.
    • Grip the fan with your fingers by the edges and lift up to remove the fan.
Sonuç
Bir Yorum
is there any way for you to do a screen replacement guild for the Acer Spin 5 SP515-51GN-807G ?
David Darvon - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 24
Her zaman: 592
